Thread: Particulate Filter Problem again
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : BMW
    Trim : SE
    Engine : 320D
    Default Particulate Filter Problem again
    My 09 CDTI 160 keeps bleeping and i keep getting the warning coming up Particulate Filter is full, in which i think it is hiding another fault somewhere.
    This is the 3rd time this has come up in 4 months and only in the last 1700 miles.
    Its been to VX had a service and they found a problem with the swirl valve which was replaced under warranty but the particulate filter warning is still coming on, i have attempted the regen several times but to no avail.
    Any ideas what i should do before i take it back to vx yet again.
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Ask Vx to remove it as it is giving you problems. They probably won't, in order to keep the Nanny State happy.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Admin plasma's Avatar
    On the Forum
    184 Post(s)
    Engine : 150
    Mileage : 74000
    what type of driving you doing Phil? short distance?
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Nottinghamshire
    Vehicle : BMW
    Trim : SE
    Engine : 320D
    A mixture matey, long trips to Stoke on Trent and several trips to Lakeside and Dartford and then the short 10 miles each way to / from work now and again.
    But 1700 miles isnt very good for a problem is it?
    Hope you are well?
    On the Forum
    184 Post(s)
    Engine : 150
    Mileage : 74000
    All ok here thanks Phil, what year car is it.. Maybe a faulty inlet manifold/EGR causing too much soot to go into the DPF.. although it should measure it and then regen accordingly....
    When you say the light has come on what light are you talking about? It was a flashing glowplug light but this was later turned off on ECU updates because too many customers were taking it into the dealers thinking there was a problem.... also when you say you've attempted regen several times how are you doing this?
    Also you can only do a max of 2 forced regen's before you may need to change the oil... As each regen seriously kills the quality of the oil with fuel being dumped into it. Also a forced regen isnt a complete answer, it just gets it down to a lower level and tells the car to do a standard regen at the next oppurtunity
    Nottinghamshire
    Vehicle : BMW
    Trim : SE
    Engine : 320D
    The big red warning screen in between Speedo and Rev Counter, just wondering if its something to do with the swirl valve replacement they done when i had the same warning and engine oil change and a service required all came up then as well, i have never had the little regen light in the speedo come on to say its doing a regen
    Driving it above 2k for miles and miles as per manual
    Its an 09 2.0 CDTI 160
    Jan 2010
    wirral
    must be an insignia then........wish my vec warned me !!!
    Nottinghamshire
    Vehicle : BMW
    Trim : SE
    Engine : 320D
    Quote Originally Posted by bafoo View Post
    Indeed it is matey..
    Jan 2010
    wirral
    hope you get it sorted as I have had no end of issues with mine!! Although they did not start until 90k!! 1700 miles is dissappointing isn't it. I ended up drilling a hole through mine although I would not have done it on an 09 plate insignia!!!
    Nottinghamshire
    Vehicle : BMW
    Trim : SE
    Engine : 320D
    Well it will be going back to vx and then i may look to get rid of it as i thought having a newish car wouldnt give me all these probs, wish i had kept my 55 plate CDTI SRI now.
  1. Removing particulate filter
    By lgtuk in forum Diesel Engine related
    Last Post: 3rd February 2011, 21:44
  2. Diesel Particulate Filter
    By bafoo in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2011, 18:06
  3. Diesel Particulate Filter Re-gen
    By RobertHayman in forum Engine & Drivetrain
    Last Post: 16th November 2010, 23:47
  4. Diesel Particulate Filter or not??
    By Drew in forum Engine & Drivetrain
    Last Post: 26th January 2009, 09:32
  5. Diesel Particulate Filter
    By Eddie Dee in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2007, 20:10
