Results 1 to 10 of 11
Thread: power steering problem...!!!!
    Regular Member rioni's Avatar
    london
    Default power steering problem...!!!!
    cheers im having a problem with my power steering its very heavy in a morning everything is ok but after 10 miles goes heavy i chek the oil ok no oil leaks nothing no warning lights etc... but is heavy on turns cAN SOMEONE HELP ME .......
    Regular Member badback's Avatar
    Runcorn
    Could be your battery or alternator mate, have em checked. The power steering uses lots of electrickery.
    london
    Quote Originally Posted by badback View Post
    could be your battery or alternator mate, have em checked. The power steering uses lots of electrickery.
    ye mate the cars starts fine nothing wrong every thing seems ok
    Runcorn
    When my alternator failed I had no warning lights or bad starting, just lost power steering.
    london
    when my alternator failed i had no warning lights or bad starting, just lost power steering.
    thank's mate i will check the alternator but the steering pump seems working when i turn the sterring i hear the pump working fine.....cheers
    Full Member Big Sig's Avatar
    As said it's electric so if it's low on power from a bad battery or alternator then it may become heavier until the battery is charged again.
    Have you checked the power steering fluid level?
    london
    Yep, mate i checked and toped 100ml but same again , battery seems fine also alternator fine but steering it's heavy after 10-15 miles journey
    vectra c 1.9 cdti SXI
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    possibly the power steering rack then
    london
    Quote Originally Posted by soulman View Post
    i'm going tomorow to check to a local mechanic what's a problem with the power steering .....cheers
    Hope it's not the pump!
  1. Power steering problem
    By Danwells72 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th October 2012, 16:25
  2. On Going power steering problem
    By gazspeight in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2011, 18:18
  3. power steering problem
    By mr.d in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2011, 22:33
  4. Power Steering Problem
    By llaregub in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2008, 11:35
  5. Power Steering problem
    By H11LGX in forum Suspension, Wheels & Brakes
    Last Post: 22nd March 2006, 01:19
