Thread: Rear screen washer problem
    Mar 2011
    midlands
    StatsVehicle Info
    Default Rear screen washer problem
    Hi my rear washer has stopped working. I removed the jet to eliminate it being faulty and it still doesn't work. so i removed the pipe from the pump and blew it out with compressed air, a load of gunk came out of the pipe then suddenly it went solid and now i can't even blow down it. someone has mentioned a 1 way valve? where abouts is this located? and are there any other joins in the pipe? also where exactly does the pipe run into the car? would appreciate your help guys
    Mar 2011
    midlands
    StatsVehicle Info
    I read in 1 of the other threads that the 1 way valve is in the elbow on the pump. I have removed the elbow to find it is just a hollow elbow connector with no valve in it. Does anybody have any idea where the valve is in the pipe or any other joins that may be causing the problem. Need your help guys!
    Jul 2009
    barnsley,yorkshire,GB
    StatsVehicle Info
    Hi steve
    at the side of the pump behind the inner wing panel there are two hoses with elbows feeding into a small cylindrical unit,this is the switchover valve for front/rear wasing you may have jamed it up with the compresed air pressure.
    Mar 2011
    midlands
    StatsVehicle Info
    cheers jonnybravo. i have swapped the front and rear pipes over. when i operate the rear washers the front ones squirt so i know that side of it is ok. i am sure there is a blockage in the pipe somewhere. Are the elbows supposed to have valves in them? if so maybe i have blown the valve out and blocked the pipe with it? where does it enter the body? is there a join here?
    Mar 2011
    midlands
    StatsVehicle Info
    Just a quick update. Got my rear washers working now. I blew compressed air down the jet end of the pipe and out popped a small piece of rubber from the pump end of the pipe. It turns out it was the one way valve that didn't appear to be in the elbow on the pump. Some tit head (me) had got carried away when blowing down washer pipe, hense blowing the valve out and blocking the pipe up. Silly me, anyway hope maybe this will help someone who also has problems with front or rear screen washers, cheers steveyd83
  1. Rear washer problem
    Last Post: 30th March 2011, 13:54
  2. Rear Screen Washer Issue
    By Kev_G in forum Bodywork & Interior
    Last Post: 21st March 2011, 00:39
  3. Screen washer problem - Please help
    By MattW74 in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2010, 12:04
  4. Estate headlight and rear window washer problem
    By henryf in forum Electrical & ICE (including SatNav)
    Last Post: 1st January 2010, 22:17
  5. rear screen washer trouble
    By dezzie in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2007, 21:54
