Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: P2279 code. 1.9 150
    Regular Member Mopar Man's Avatar
    herts
    Default P2279 code. 1.9 150
    Just done a few hundred miles in the vec, dropped me girlfriend of at stansted. Car was switched of for 5 Min's, when i got back in and drove of, the EML light came on and went into limp mode. I switched it of and restarted and power back, but not for long. Kept doing this all the way home, but went back into limp mode.
    Iv just plugged it in and the code is P2279 Intake air system leak detected? Tried it for a few miles and no codes after clearing.
    It does seem a little under power though under 2000rpm then lifts of like a scalded cat, with a bit of soot.
    Any body come across this before, if so what was it. Thanks Alan
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    EGR valve possibly or split in Intercooler/boost pipes.
    Gazza4
    Regular Member benny's Avatar
    Feb 2006
    dudley
    does it have a dpf fitted ?
    herts
    No DPF and the EGR was deleted when the remap was done.
    herts
    I will check the pipes, but would have thought that it would be permanent limp? No hissing noise
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Mopar Man View Post
    Have you blanked the valve off? It may be jammed open slightly.
    Gazza4
    scottish region
    have u had the airbox unplugged or removed recently
    herts
    Not touched the air box recently.
    The egr is blanked off Gazza.
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    That's what mine does. Restarting a warm engine. My remapped explained that it's impossible to fully delete EGR operation, so at a certain temperature (I think it's when inlet temp is above 50 degree due to heat soak from radiator) the ecu requests the EGR to open, and when it doesn't open it puts a fault up.
    Mines remapped, with EGR and DPF delete as well as a blanking plate on the bottom of the EGR valve. I run a Scangauge, and watch the inlet temp so can see when the temp goes above 50 and the fault light appears. It's easy then to check the code and reset it while still driving.
    I'm glad I'm not the only one that this happens with.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Ok m8 favoured question with this engine (only a matter of time) - swirl bar still connected?
    Gazza4
  1. P2279 Fault Code - Ait Intake Leak
    By McLovinH in forum Engine & Drivetrain
    Last Post: 20th September 2012, 17:54
  2. Fault code P2279?
    By Phil MC in forum Engine & Drivetrain
    Last Post: 8th July 2012, 19:29
  3. 1.9 CDTI fault code P2279-11
    By mozzer99 in forum Engine & Drivetrain
    Last Post: 14th June 2011, 20:13
  4. fault code p2279
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2010, 20:14
  5. Fault code P2279 Showing.HELP!!!.Info PLEASE.
    By felixx in forum Engine & Drivetrain
    Last Post: 28th October 2010, 18:34
p2279 opel 1.9 cdti
opel vectra c 1.9 cdti p2279
p2279 breather pipe
vectra c 1.9 cdti p2279 camshaft
p2279 opel vectra
08 1.9 tdci vectra code p2279
p2279 fault code www.vectra-c.com
vectra c 1.9 cdti cod p2279
