Thread: Just had air con regassed but...
    Regular Member TomiboyC's Avatar
    Aug 2007
    East Ayrshire
    Default Just had air con regassed but...
    As title says just got air con regassed, print out given indicated that there was zero refrigerant remaining so filled up and running fine apart from what looks like smoke arising from condenser and also had a little burst of it through the footwell, is this normal after being refilled from empty?
    Any help appreciated
    Tommy
    Regular Member Marcosuk's Avatar
    Fife
    U checked for a leaky pipe??
    Aug 2007
    East Ayrshire
    print out given indicated it was pressure tested and no leaks detected, given that there was nothing left in it i was expecting to be told that there was a leak so i'm a little bit confused here
    Engine : 1.9 CDTi
    How long did they hold the vacuum for as it should be at least 30 minutes to detect leaks.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    iirc alot of places don't vacuum it the fill it with nitrogen and check for pressure loss
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    No aircon expert, but I've never seen any sort of smoke coming from one, I's suspect a leak, maybe a small one. If it's coming into the car I don't think breathing it is likely to be a good idea.
    Aug 2007
    East Ayrshire
    definately got a leak as its not working again, lasted about two hours from gettin it filled. the test they did ran for about 25 mins, then another 10 mins. to fill it, guess it'll be a journey back to get money back!
  1. Aircon regassed week ago now not working?? :(
    By dawn78 in forum Engine & Drivetrain
    Last Post: 1st August 2011, 16:39
  2. Need a favour from someone with air con thats needing regassed
    By John LE in forum Engine & Drivetrain
    Last Post: 9th May 2011, 18:17
