Thread: What the heck?? help
    Regular Member bizerk's Avatar
    EDINBURGH
    Eek What the heck?? help
    HI all
    Just read on here that you can do the pedel trick to find out fault codes, so though I would give it a try.
    Car runs fine, except for the faulty battery that wont hold a charge (awaiting a new battery in the post) so didnt think there would be many,,,
    I have the codes and matched them up with their faults, but can anyone please tell me what these codes actualy mean and could it have anything to do with my faulty batery? (please dont tell me to scrap my car lol)
    1483 - Power to fan circuit overcurrent
    0170 - Fuel trim malfunction (bank 1)
    1565 - Speed control command switch out of range high
    1525 - Air bypass valve system
    1550 - PSPS out of self test range
    Thanks all
    My cars is a Vec C 1.8 2003 LS
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Depending on when the codes were last read those codes could be ancient. Disconnect the battery for 15 mins to reset and then try the pedal test again
    EDINBURGH
    The battery was disconnected all friday night, when I was charging the battery, only thing I have did since then was vaccuum out the air filter box.
    Ive also not driven the car more than 20 meters since refitting the battery.
    Regular Member Marcosuk's Avatar
    Fife
    If you were closer mate id clear your codes for you ... Then you could go from there..
    EDINBURGH
    Is there somthing I can buy to clear the codes?
    Fife
    Ive got an autel ms509 which works fine..
  1. Flippin Heck!! How Much?????
    By Ian-Highlander in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2010, 19:32
  2. What the heck is this!?
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 2nd August 2008, 11:46
  3. what the heck is going on out there ???
    By veccy22 in forum General Chat
    Last Post: 7th November 2007, 11:59
