Results 1 to 10 of 24
Thread: camber question after lowering
    Regular Member Mads's Avatar
    Ipswich,.UK
    Default camber question after lowering
    hi
    i have recently lowered my sri with eibach pro kit and have just come across some threads about knocking noises and cambers. I dont have any knocking noises but ive read you can get uneven tyre wear etc.
    when you lower a car do you have to take it in to get a 4 wheel alinement and camber check and if so where can do that as i read some places cant check the camber? what have other people done after lowering their cars?
    like i say as far as im aware i dont have any problems but i just wanted to make sure all was ok.
    many thanks
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    i had a four wheel allignment done on mine after i first lowered it, it was not out by much at all but the piece of mind was worth it.. I will be booking another 4 wheel allignment this coming week if I can get a slot.. Its worth doing if you have bounced of a kerb or a pot hole or two during the winter.. it costs less than one tyre for a 4 wheel allignment so i have a no probs in getting it done anyway..
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    I would get the camber corrected, mine is chewing tyres on the insides after lowering.
    Gazza4
    Ipswich,.UK
    Wheres a good place to get it checked?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Never had my sri done after lowering, the handling is great and tyre wear normal for a car with multi link suspension.
    May make a big difference on a non sports chassis car but I don't think there would be much difference on a sports chassis car
    Ipswich,.UK
    Thats a good point i will have to check the threads i read earlier to see if the problems were with non sri models. i think i may get the 4 wheel alinement check though has the car is fairly new to me (dec 2010) and im unsure when it was last checked.
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Been thinking about the same thing recently. Lowered mine a few weeks back.
    Heard Hunters is best for 4 wheel alignment.
    Did a search on the net For Hunters in Macclesfield and found a place nearby.
    Paid them a visit and they charge £85 for check and minor adjustments.
    Not booked it in yet, as they said probably wont need adjusting just for lowering it.
    So im in two minds as what to do.
    Jun 2009
    South Coast
    Just got my car back from having it aligned again (had a nasty kerbing session during the winter). They have adjusted some bits as I expected they would have to do and the corner I had to fix is now spot on. However the NSF where i did not replace any suspension components will need more work.. I reckon i will replace that shock as well then and see if that sorts it, I reckon it will but have nothing to loose. At least I have piece of mind that my fixed corner is spot on as I have the MOT coming a few weeks.
    Regular Member Mopar Man's Avatar
    herts
    Just checking something here. Iv fitted sri springs and shocks to my Elite.
    Why do they call it sports chassis on the sri, thought all the chassis were the same? Or is it just the geometry set different.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Yet again, the Hunter website only lists sites where their equipment is installed and they don't endorse any of the garages. Hunter have zero experience or knowledge of the garages or the muppets using the equipment.
    This doesn't apply to all Hunter equiped garages but, as the saying goes, "buyer beware".
    This link is taken from "Wheels in Motion (WIM)" and the sites listed across the country follow the original ethos of WIM http://www.blackboots.co.uk/tyre-fitting-centres.php. Read WIM's homepage to get an idea of what geometry should be about and how it's done properly.
    HTH
  1. Lowering Question?
    By Del101 in forum Suspension, Wheels & Brakes
    Last Post: 27th January 2013, 18:28
  2. lowering question
    By davidmcd2002 in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 15:32
  3. lowering question
    By MSharkey in forum Styling
    Last Post: 15th October 2009, 11:22
  4. Lowering springs & camber adjustment
    By DTGB in forum Handling & Braking
    Last Post: 29th September 2008, 21:06
  5. Another lowering question !
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2008, 12:34
vectra c lowering problems camber
