Thread: Few issues with a CDTi 120 (2007)
    Regular Member tosh23's Avatar
    HULL
    Default Few issues with a CDTi 120 (2007)
    Ive been abusing the search button over the last few weeks, and now I confused. I didn't want to post silly questions that have been posted a million times before but for the life of me I cant find the thread that gives me the answer to my question SO I apologize for my stupid question...
    Vectra cdti 120 (2007) design estate 115000 miles.
    The car has a few things wrong with it so im starting with one thing at a time. My idler pulley is screaming so to find the air noise of a split vacuum hose is impossible at the moment..
    Its a simple question really....
    Should this big pipe expand in width when I rev the engine...
    If not does this signify the EGR is not opening or that one of the many pipes is either blocked or split...Usual juddering after EGR and boost sensor have been cleaned...
    Once again Im sorry for the stupid question but that search button is SO addictive...............Tosh
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Yes it should go solid and expand slightly. Thats a boost pipe, it's where the turbo forces air through
    HULL
    Cheers John, I will keep looking, I can hear a whooshing sound but I cant get to it due to the pulley screaming. I guess when I fix the pulley I can then get to the juddering problem....Cheers anyway...........Tosh
    north east
    Directly under your hand in that pic is 2 of the 3 vacume pipes going to the boost solenoid on the slam panel, the one from under the engine cover to the slam panel is common for failing.
    HULL
    Dear Roswell,
    You were spot on mate...I bought a one meter hose and replaced the long one from under the engine and the one you suggested, now im getting 40 mpg an increase of 7 mpg for a couple of quid....****** well done mate.....Tosh
  1. 1.9 cdti 150 eml & EGR & DPF issues
    By carvaletingpro in forum Diesel Engine related
    Last Post: 24th August 2012, 08:16
  2. 1.9 CDTI 150 - Issues
    By me9141 in forum Engine & Drivetrain
    Last Post: 27th April 2012, 17:56
  3. cdti 150 mpg issues
    By Kcs in forum Troubleshooting
    Last Post: 23rd December 2011, 23:44
  4. Issues with CDTI 1.9 SRi 150
    By warren77 in forum Engine & Drivetrain
    Last Post: 14th May 2011, 12:12
  5. 3rd injector issues 1.9 CDTi 150
    By @ndy-e in forum Engine & Drivetrain
    Last Post: 24th November 2010, 21:21
