Results 1 to 10 of 11
Thread: batt light on dash
    Regular Member mitch's Avatar
    WIGSTON, LEICESTER, LE18
    Default batt light on dash
    last wed i noticed this come up on dash but then went out, on the way back home from work thurs it come on again, but stayed on. then the abs came up then the steering went stiff very dangerous, got it home went to start it and it was dead, took batt off put on charge. the batt been off since then will it affect owt when i re connect it as in service lights or faults on dash. ive asummed its the alternator at fault is this correct guys?? its in tues at local garage to have new one fitted so all this hol am on a bike, am unfit!!!!!!!!!
    Aug 2010
    Leeds
    Id say it's your alternator have you checked the output voltage?
    This battery may also require changing if it's almost 3yrs old as they fail when flattened.
    Regular Member badback's Avatar
    Runcorn
    Sounds similar to mine when the Alternator bit the dust.
    Quote Originally Posted by Bigtee View Post
    i check batt and alternator output at my works workshop and it was down on input.
    the batt had the green spot indicator but this went when didnt start, ive been charging it on and off since thurs and the green indicator has returned and charger is only pushing in 1 amp now?
    Aug 2010
    Leeds
    When the battery is fully charged put it back on fire the beast up and check the voltage at charge and do this with the headlights on to put a surge on the alternator.
    Your looking between 13.6-13.84 ish for a fully charged battery, below 13v or above 14. and replace.
    it was 11. something when checked before it died, i was thinking when charged and new alternator fitted it would work its self back up to full charge?? is this wrong, how much is a new batt folks
    Aug 2010
    Leeds
    Batteries seem to die after 3yrs or at this age and like yours get run down, but if yours is not this old it may be fine, so replace the duff alt and try it if it's ok you have cracked it if not you know what to do.
    Cost on batts varies as there cheaper in summer than the winter demand so shop around for prices even try vx.
    All back up and on the road again, £290 quid lighter mind you for new alternator, battery seems fine so thanks for the info guys
    May 2006
    scotland
    My battery is original (car registered December 2004) and seems ok at present. 3 years seems a bit of a short life.
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Quote Originally Posted by mitch View Post
    was that fitted?
  1. abs light on dash help!!
    By tripletdad in forum Suspension, Wheels & Brakes
    Last Post: 25th March 2011, 09:19
  2. light on dash
    By Keithy in forum Suspension, Wheels & Brakes
    Last Post: 23rd October 2009, 19:05
  3. Light on dash...
    By dankidd in forum Engine & Drivetrain
    Last Post: 17th December 2008, 01:13
  4. light on dash
    By vectragsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2008, 16:45
