Thread: Emissions light after EGR removal
    Huntingdon
    Default Emissions light after EGR removal
    Hi all,
    I have a 2006 1.9 cdti and decded to clean the EGR. After tsking it off it appears it is quite new (April 2010) and didn't need cleaning.
    After putting it back on and going for a drive I got the spanner light.
    Stopped the car and restarted and it has now gone but has been replaced with the emissions light.
    Fuel economy is fine as is the performance, what can I do to next?
    Tried to find the fault code using the pedals procedure but nothing happened, no flashing lights.
    Antwerp, Belgium
    Quote Originally Posted by gr1340 View Post
    Hi all,
    i uses once a special product for cleaning the intake and egr (provided by the official garage) and immediately the exhaust light came on too.
    car ran perfect as before and after resetting via tech2 it came back 2 days later.
    only thing that helped was new egr valve
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Did you use a new gasket when re-fitting the EGR? If not, the old one might not have sealed properly. Also, check the contacts on the connector that plugs into it
    Alternatively, blank off the EGR completely, and get the ECU remapped to remove teh EGR from it completely, thus putting the warning lights out.
    Huntingdon
    Good point about the gasket, I will check that this afternoon. Thank you
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Did you plug it back in/properly? Or it sounds like the valve me be jammed in the closed position. Have a couble check and also replace the gaskets for all they cost.
    Gazza4
    Jun 2009
    Dover
    I had the same thing.After replacing EGR with the new one I had no lights on the dash and car was fine.Then I put a foot down as I was chasing my mate and light come on.I thought that some bolts could be undone,but when I removed the engine cover I found that plug just unclipped itself that's why car was fine even with emission light on
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Something similar happened to mine, so the plug is now zip tied in place.
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    Hasn't there been talk of some EGR valves that needed vauxhall to do something with the ecu to make the car accept them?
    Huntingdon
    Update - emissions light was off today so hopefully it was just a false alarm.
    I was going to take it off again and check the gasket next weekend but won't bother now.
    Thank you for your help
  1. Emissions light
    By shuggler in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2012, 19:16
  2. Emissions Light
    By battle84555 in forum Engine & Drivetrain
    Last Post: 20th February 2011, 19:56
  3. Emissions light on!!!
    By Bad Ad in forum Engine & Drivetrain
    Last Post: 16th January 2011, 22:37
  4. Emissions Light
    By MultiDropper in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2010, 23:42
