Results 1 to 2 of 2
Thread: CDTI 150 water pump / cambelt failures - has it happened to you ?
    Apr 2011
    Somewhere
    Default CDTI 150 water pump / cambelt failures - has it happened to you ?
    Hi all
    Recently, the water pump siezed on my CDTI 150, which shredded the cambelt, broke the rockers (and maybe more - still won't run - being stripped down further now). Car is 4 years old, only into low 50k miles, full service history.
    I now see that this isn't an unknown problem, seen it on several forums and other sites like Honest John etc.
    If you (or anyone you know) has had this happen, could you post a brief bit of info here ? Car, engine type, mileage at failure, service history, damage done & cost of repair ?
    Just trying to gauge how common this problem is.
    I've also read somewhere that VX know about the problem and are advising water pumps to be changed by 40k miles. If anyone can provide me with a document reference number or similar that shows this to be true, I'd be eternally grateful
    Thanks!
    Regular Member vanquis1979's Avatar
    gainsborough
    my 150 cdti sri xp had this trouble 3 weeks ago done 109000 miles and had belt done at 100k but lucky for me i was sat in traffic when i noticed the smell then smoke turned it off and towed to my mates garage! turned out water pump siezed solid and a tensioner the belt was nearly off!! so had belt tensioners and pump done now spot on
  1. Just had cambelt & water pump done
    By aps in forum Engine & Drivetrain
    Last Post: 1st July 2012, 11:46
  2. Cambelt & Water Pump
    By Aidi in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2012, 00:48
  3. 3.0 v6 cambelt/water pump
    By bigsteve3.0v6 in forum Y & Z30DT Specific
    Last Post: 11th September 2011, 23:44
  4. 3.2 v6 GSi cambelt and water pump
    By MAF 3.2 V6 GSi in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2010, 20:07
  5. 1.9 CDTI 120PS Cambelt / water pump
    By acled in forum Engine & Drivetrain
    Last Post: 11th October 2008, 23:57
vectra c 150 cdti waterpump
water pump vauxhall vectra c 150 sri 2008
