Results 1 to 10 of 10
Thread: Cd30 mp3
    Regular Member Steven's Avatar
    Jan 2006
    Dalriada
    Default Cd30 mp3
    I have just bought a CD30 MP3 unit to fit to my car, it came out an astra or corsa. Now does anyone have the part numbers off the wiring loom that runs off the back of this unit, its the same loom that is in the astra and runs below the handbrake and accepts the 3.5mm jack from an MP3 player..
    I'm going to ask the same question on the astra forums too, but i thought i would try on here first..
    Jan 2006
    Dalriada
    Another quick question, Does a divorced unit need reprogrammed into the car via tech2 to allow you to get full screen workings instead of saying "safe" on the screen??
    Regular Member lochgilp's Avatar
    Mar 2006
    argyll
    Steven 99% sure it will need paired to your car via tech 2 mate
    Jan 2006
    Dalriada
    It will Scott and i have also found out what leads i need via google
    Mar 2006
    argyll
    why do u want to change it????
    Blantyre
    To Play MP3
    Jan 2006
    Dalriada
    Quote Originally Posted by lochgilp View Post
    So I can run the ipod from it, and didn't fancy going down the single din way again..
    Mar 2006
    argyll
    Thought u were going down the parrot route sound much better that the cd30 unit and full control of you ipod and charge, usb, sd and not just the awkward aux input
    Regular Member bigsteve's Avatar
    Apr 2008
    Nottingham
    Quote Originally Posted by Steven View Post
    Steven, Please let me know which lead I need as I am desperate to do the same..................!
    Jan 2006
    Dalriada
    http://cd30mp3.co.uk/
    This is the site i have seen mate - maybe a little expensive for the leads but its guranteed to work
  1. Fitting Parrot MKi9200- Can it run through CD30 aux?(does CD30 even have aux!?)
    By dibble750 in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2013, 02:20
  2. Quick CD30 to CD30 MP3 question
    By Chip in forum Electrical & ICE (including SatNav)
    Last Post: 24th August 2012, 00:47
  3. Cd30 & bid
    By KyleSxi in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2012, 15:50
  4. CD30 to CD30 MP3 Conversion
    By yysnet in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2010, 00:20
  5. Replacing CD30 with CD30 MP3
    By Marky in forum Electrical & ICE (including SatNav)
    Last Post: 15th August 2007, 13:38
