Results 1 to 10 of 27
Thread: vectra and torxs bolts why??
    Regular Member daveypower's Avatar
    Mar 2011
    Donegal
    Default vectra and torxs bolts why??
    what the hecks up with the torx bolts, had serious serious problems doing my front pads today never have i seen bolts so tight, busted my good half inch rachet, busted my nose open with a spanner, and also rounded my sump plug, what heppend to good old standard bolt hex heads??.
    also rounded a wheel stud
    Regular Member scotty84's Avatar
    Dec 2010
    Boosting in W.Mids
    Vehicle : Saab 9-3 Aero
    Trim : Aero
    Engine : 2.8 Turbo V6
    Mileage : 62000
    Bad times dude. Had same problem when replaced my rear discs/pads, I think next time I will pay the £40 labour to have them fitted lol............I made sure I brought new bolts from vx they were about £1 each.
    Mar 2011
    Donegal
    Quote Originally Posted by scotty84 View Post
    haha yea they arent worth the hassle, thought i was going to get 2 black eyes when i hit myself dunno how i managed to, completly slipped and spanner busted into my nose lol, all over pads ha. sump plug just turned into a circle it was so soft. im coming to think nothings easy on these cars.
    Dec 2010
    Boosting in W.Mids
    Trim : Aero
    Mileage : 62000
    I took a chunk of flesh from my pinky lol and slipped n headbutted the door lol....... That was just on the first bolt.
    Mar 2011
    Donegal
    hahahaha thats a good one man haha. ya gotta love the cars.
    Regular Member tosh23's Avatar
    HULL
    Has anyone tryed the torx with an air impact driver ? can you get one in there?.....Tosh
    Regular Member jimmyred's Avatar
    Dec 2010
    Southport
    I think the idea of torx is that they are less likely to slip and round off...the spanner or head has a better grip. In practice not always the case. Also this means they can be tightened up much too much!
    Aug 2010
    Leeds
    Quote Originally Posted by daveypower View Post
    You need a strong bar to crack off the bolts first before you use your ratchet and also worth buying quality impact sockets which take more force.
    The torx is to stop the diy motorist from doing jobs on cars as it's more of a specialist tool rather than the norm socket set.
    Air gun used here for large bolts above say 19mm socket size no need for anything below that.
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    As above, get yourself and good set and a breaker bar.. Not come across one I couldnt undo yet.... also helps with an impact gun
    Regular Member Keif's Avatar
    In the Garage
    Never had any problems with Torx bolts.
    Sump plug was obviously over tightened, only needs to be tweeked past hand tight.
    Did my rear disks and pads a few weeks ago and the only torx bolt to undo is the one holding the disk onto the hub, not exactly tight?
  1. For Sale: 4 x10mm spacers, spigots, longer bolts and locking bolts
    By 6009tristanb in forum Parts for sale
    Last Post: 25th September 2011, 20:02
  2. Front bumper removal can only see 2 torxs
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2011, 12:50
  3. Vectra Carrier Bolts - Need to be replaced?
    By yoclick in forum Handling & Braking
    Last Post: 25th September 2009, 20:09
vectra c using hex sump plug www.vectra-c.com
