Results 1 to 10 of 14
Thread: 2004 Vectra 2.2 direct SRI
    Apr 2011
    edinburgh
    Default 2004 Vectra 2.2 direct SRI
    I am hoping someone can help my brother. His car will start and idle but dies when he tries to rev it up. He has changed all the sensors, pressure regulators etc but to no avail. He has had the car checked for error codes and they show then clear, show again and then clear again. The tech guy seemed baffled. Could this be down to a broken cable, faulty ecu? Your help would be appreciated
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Mileage : 137000
    Will it drive at low revs, then when you put it under load or get to 2500rpm+ is starts running into trouble?
    Apr 2011
    edinburgh
    Have spoken with him this morning and the only way to get it started is to disconnect the fuel pressure regulator then put it back on. It will rev up but dies under load. He has changed the regulator and pump as well as the egr valve as well as other sensors etc. It's the irregular ecu faults that is confusing his electrical guy.
    Vehicle : 9-3 Wagon
    Mileage : 137000
    Is the new pump made by Continental or Siemans?
    Apr 2011
    edinburgh
    Thanks for your quick reply. He is not sure but it was supplied by Vauxhall. I have asked him to have a look but he is away till Tuesday
    May 2009
    swansea
    Pump in the tank faulty?
    Vehicle : 9-3 Wagon
    Mileage : 137000
    Quote Originally Posted by calumritchie View Post
    That will be fine then mate as they will have supplied the Continental one then.
    Regular Member scotty84's Avatar
    Dec 2010
    Boosting in W.Mids
    Vehicle : Saab 9-3 Aero
    Trim : Aero
    Engine : 2.8 Turbo V6
    Mileage : 62000
    Its very similar as mine was with a faulty fuel pressure regulator. Ive heard of people buying new ones that end up being faulty......
    Apr 2011
    edinburgh
    Is there anything else that he could check before going along the new ecu route as I imagine this is going to be costly. He has spent over 600 quid so far on thi
    Mar 2011
    armagh
    Smile
    hi i have the same car. had the same problem las year tryed everything. then took the pump out off petrol tank clean it out car was dead on since
  1. Replies: 9
    Last Post: 25th August 2012, 18:14
  2. 2004 vectra sri 2.2 direct
    By crap vectra in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2011, 21:38
  3. P0141 on Vectra 2.2 direct petrol 2004
    By chips in forum Vectra C / Signum Troubleshooting
    Last Post: 20th September 2010, 18:41
  4. 2004 Vauxhall Vectra 2.2 Direct SRI
    By Curly7 in forum Cars for sale
    Last Post: 1st June 2009, 16:43
  5. 2004 vectra sri 2.2 direct
    By spennny in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2009, 13:23
opel p1170-17
