Results 1 to 10 of 21
Thread: Cruise control not working in 5th gear??
    Dunstable
    Default Cruise control not working in 5th gear??
    Hi all, as some of you may know my gearbox went up the spout last week and I have had a recon one fitted along with a new clutch. All is great with it, but I noticed tonight that the cruise control doesn't work when in 5th gear. It works fine and dandy in all other gears apart from 5th. It worked fine before I had the work done, any ideas why it would work fine apart from in 5th? Will be taking it back to the garage nxt week, but am curious as to why this is happening.
    Cheers guys!
    Dunstable
    Anyone?
    Dunstable
    Mileage : 000
    I would have thought if it was going to "play up" it would do it in all gears. Maybe the switch in the clutch pedle has been moved.?
    Sodding Typical on Sea
    Doesn't make much sense unless it is the clutch pedal switch not engaging again when in 5th,,,, weird or what?
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Does it do it at higher speeds too? Mine won't engage if I'm driving slowly in 5th. Say about 30mph it won't come on. Higher speed it does though.
    Quote Originally Posted by Ademusic View Post
    What minimum revs and speed?
    Antwerp, Belgium
    my cruise control defect was caused due to malfunction of the cim module
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Revs need to be at 1100rpm or higher, and road speed at 31mph or higher, for the CC to work
    Quote Originally Posted by tony-1977 View Post
    Not on the V6 CDTI, you can take it right down to 15mph and 700rpm
    It can't be engaged in 1st gear though
    Just make sure you press the brake pedal before use, to activate
  1. cruise control not working
    By bigron1988 in forum Electrical & ICE (including SatNav)
    Last Post: 10th June 2011, 19:49
  2. Cruise Control - working again!!?
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2009, 19:30
  3. Cruise control not working
    By tommyk999 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd March 2008, 11:13
  4. Cruise Control not working
    By jonnyc in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2007, 04:53
  5. cruise control not working?
    By j1 wyx in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2007, 00:54
2012 gt500 cruise not working in 5th gear
cruise works in 5th bun not sixth
opel astra h cruise control 5 gear not working
c vectra tempomat in 5th gear
cruise control wont engage on fifth gear
