Results 1 to 10 of 22
Thread: Car won't start after head gasket change
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Default Car won't start after head gasket change
    Car is a 54 plate vectra c v6 cdti.
    changed headgasket an replaced all belts etc.
    Checked the timing marks an double checked. Now it cranks at full speed but not firing a sprayed a some carb cleaner in whilst cranking an it trys to fire but then cuts out.
    I think it's fuel related. Could someone tell me which way round fuel lines are connected at filter? And also any ideas as to what it could be for not starting
    No fault codes showing either.
    Regular Member poves's Avatar
    lancashire
    I know people say the newer diesel engines are self bleeding , but try filling the filter housing up with diesel , I had the same problem once after taking the lines off , hopefully could be something simple ?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Maybe worth firing in a new diesel filter too
    Apr 2011
    midlands
    i have just had problems with my injectors and have been told by the AA and RAC that the metal fuel pipes that go from the carage to the injectors can only be used once and if removed they should be replaced. also look out for air bubbles coming from round the top of the injectors it may well be a seal thats gone on them. but as for the fuel pump it is said to be a high pressure pump and shouldnt need bleading.
    hope this helps
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    cheers guys will give it a blast in the morning, i replaced the fuel filter so tht should be ok.
    the injector pipes seem fine, we from what i an see anyway.
    does anybody no if theres a hand primer anywhere? just so i no then im definatly getting fuel
    Regular Member daveypower's Avatar
    Mar 2011
    Donegal
    Quote Originally Posted by CritchvxD View Post
    can you take of any of the injector pipes and turn the car over to see if any fuel is coming out? just a thought.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by daveypower View Post
    yeah i thought that before mate, some of the electrics etc are in the way.
    th car has only got 10 or so litres of fuel in some gonna stick another few litres in and also make sure the fuel filter s full, then ill give blast at cracking the injectors.
    just wanted to no if i had a hand primer as that way i would no for certain i had fuel up to high pressure side or not as the case maybe.
    will get out and get me hands dirty tomorrow morning.
    hopefully its something simple.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    This is my V6 cranking after we replaced the injectors.
    http://www.youtube.com/watch?v=HdrMgVv1iWk
    You may want to try and crack the injector pipes (nuts at injectors) open and get a mate to crank the car over. When you see diesel dribbling you know the system is free of air. You tight the nuts up again and you're ready to go.
    Mar 2011
    Donegal
    yea hopefully you get it sorted man, nothing worse haven a car that aint going, seems like it aint getting fuel as you said. let us know how you get on
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Cheers guys will give it a shot in the morning and see how it goes. I thought that it was a self bleeding system but a surpose it ain't gonna do any harm to crack em off an make. Looks like my little brother is Gettin his backside off the xbox an outside for the day lol
  1. Help after cambelt and head gasket change
    By mdibb2009 in forum Engine & Drivetrain
    Last Post: 15th July 2011, 06:31
  2. Head gasket change
    Last Post: 6th July 2011, 20:11
  3. 3.2 v6 head gasket
    By brooky888 in forum Introduce yourself.
    Last Post: 28th January 2009, 19:44
  4. head gasket
    By jools in forum Engine & Drivetrain
    Last Post: 30th December 2008, 09:26
  5. Head Gasket
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2007, 17:28
1.6 tdci not starting after replacing head cylinder gasket
My opel vectra 1.6 wont start even after a new top cylinder gasket replaced
corsa c wont start after head gasket change
Renault espace not turning over after head gasket replacement
vauxhall meriva wont start after head gasket change
why your car wont start opel corsa
will insignia diesal take a lot of starting aftet i changed head
how to open opel vectra c head gyas kit
z18xe wont start after head gasket
