Thread: Drivers front window not sealing properly (pics)
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    Default Drivers front window not sealing properly (pics)
    Ok, so when I first bought the car I noticed there was wind noise coming from somewhere, I've never really searched for the source properly but I knew it was coming from the drivers window/door somewhere as I could feel the air getting through.
    Anyway, today I was fitting my front wind deflectors when I noticed this (gap between seal and edge of window)
    It's obviously what's causing the leak, but what is causing this?
    I've noticed a potent "clunk" sometimes when the window is would fully down, any suggestions?
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    check the window seal it might be slightly twisted out of shape
    Engine : Z20NET
    Window seal looks fine, the window isn't actually meeting the seal at that point though, look at the gap
    Regular Member poves's Avatar
    lancashire
    The mechanism and third arm are riveted to the inner door skin , if you take the door panel off , check that the riveted joints are ok , and then check the mechanism is not kapput.
    wirral
    42 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    i had it on one f the cars in work where the seal was twisted an stopped window going up properly,
    if not as said check mechanism
  1. Free: Free Front drivers window switch.....
    By Sebastian in forum Parts for sale
    Last Post: 4th November 2012, 21:11
  2. Replies: 1
    Last Post: 4th November 2012, 20:12
  3. front wipers not parking properly
    By Daywalker in forum Electrical & ICE (including SatNav)
    Last Post: 6th October 2010, 17:31
  4. Pics at last finally cleaned properly
    By Steves-Vec in forum Detailing and Car Care Discussion
    Last Post: 11th September 2009, 08:40
  5. Front drivers side door window weatherstrip out of housing....
    By Stevie-B in forum Bodywork & Interior
    Last Post: 4th March 2009, 16:36
