Thread: Slight ticking on start until warm on 1.8club?
    Apr 2011
    Swansea
    Default Slight ticking on start until warm on 1.8club?
    As you can see from the thread name the car has a tick that sounds rubbish until its warm then its fine.
    Does it need a flush?
    Mileage : 000
    Might be warn "hydraulic tappets" ( they tend to drain the oil out when worn, then rattle a little till they have filled up again).I don,t think an oil flush would do any good. In fact I myself would not recomend an oil flush at all.
    Apr 2011
    Swansea
    brill, so is an oil top up something i could do?
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    how long since you had the oil changed gaz.
    Apr 2011
    Swansea
    around a year dude, i followed the advice of the guy at the parts store on which oil and stuff.
    Jul 2009
    Engine : 20 Dti
    depends what milage you have done since the change,if the oil is tired new oil may cure the noise with good viscosity.there's no substitute for a good quality lube oil and filter
    Apr 2011
    Swansea
    brill, thanks matey!!
  1. Car won't start and ticking again
    By n8sby in forum Engine & Drivetrain
    Last Post: 19th January 2013, 21:03
  2. Replies: 9
    Last Post: 15th January 2013, 14:16
  3. Must push Accelerator when car is warm to start. Why??
    By Tank988 in forum Engine & Drivetrain
    Last Post: 8th November 2012, 00:33
  4. z20net - ticking noise from engine when warm
    By buggy in forum Engine & Drivetrain
    Last Post: 21st January 2010, 00:05
  5. Engine ticking for 30 secs after start up
    By clive3373 in forum General Chat
    Last Post: 2nd May 2009, 22:24
vectra c 1.8 slight ticking from engine
