Results 1 to 10 of 19
Thread: Black Soot Everywhere!
    Kent
    Default Black Soot Everywhere!
    Well after getting a couple of limp home moments I decided to have a quick look around the egr valve area, will be looking at cleaning the egr and boost sensor tomorrow but need to check something.
    I removed the intercooler hose above the egr valve and looked through what I believe to be a throttle body as it had the butterfly plate (basically the part the intercooler hose connects to)
    It looked a little gunked up so I removed this throttle body which is 4 screws and my god there is black soot everywhere, I dont expect it to be clean but surely this is probably my problem, however Im not sure how I would go about cleaning this out, fair enough I can remove the throttle body, boost sensor and egr vale and clean then but there is a large build up of soot in the part the throttle body sits on, how would I go about cleaning that out, and what is this part?
    It doesnt look like it comes out very easily so Im not sure I could remove it so would need to clean in place, Ive attached a couple of pictures of what I found
    Regular Member wingz123's Avatar
    Mar 2011
    M4 Junc 12
    mate just get in there and spray loads of carb cleaner down it - leave it 20 secs then wipe out with a cloth...simples tutt!
    Mar 2011
    M4 Junc 12
    mine was like it by the way and I have been having the same problem recently......mine was partially due to this as well as having the wrong hoses fitted! lol
    Regular Member benny's Avatar
    Feb 2006
    dudley
    that is actually clean for a dti .....
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    there's a big recent post on here about taking the intake manifold off and cleaning it.
    al.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    im sooooo tempted to take mine off but its running perfect so im more inclined to leave it lol.
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    thats what mine looked like on my dti i wanted to clean mine but didnt know how to take it off or if i would damage anythink in the process
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by benny View Post
    Ours is much cleaner.
    You just have to drive the car like you stole it and the manifold is clean 130k and still going strong
    West
    Quote Originally Posted by Celes View Post
    agreed
    it's the best way to run an oilburner
    Kent
    Thanks guys,
    Will do egr and boost sensor in the morning but:
    If I spray carb cleaner in there it won't scratch the surface will it, and I wouldn't be able to check the manifold is all dry before starting the engine, would this matter?
    If I drive it at high revs it won't clean out now I guess?
    Is there any additive I can add that will clean and keep it clean?
  1. Black soot around exaust pipe
    By TopRod in forum Detailing and Car Care Discussion
    Last Post: 5th July 2011, 11:04
  2. Black soot/smoke when revving the engine
    By tigro in forum Engine & Drivetrain
    Last Post: 30th October 2010, 14:41
  3. black soot/smoke under heavy load
    By paul_sri150 in forum Diesel Engine related
    Last Post: 4th August 2010, 13:29
  4. remapping/egr soot
    By bignak in forum Diesel Engine related
    Last Post: 23rd July 2010, 06:58
  5. dpf and soot???
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 9th July 2010, 14:33
