Thread: Gear Oil over filled....!
    dudley
    Default Gear Oil over filled....!
    Signum, 2.0 dti, manual F23 Box
    Checked the oil level of my gear box yesterday and to my shock I managed to drain a litre of oil out of the level plug, it came gushing out. Damage has already been done, N/S drive shaft seal leaking. My question is how did this happen. I've owned the car since May 09, done 18,000 miles with no leak. The only time some else has worked on it is when the clutch was changed in January, is there any need to drain and refill the gear oil before a clutch change, if so someone going to be getting a call.
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Yes it will be drained as the gearbox has to be removed the oil will be drained and refilled when fitted mate
    Oct 2007
    Shropshire
    Vauxhall overfilled mine....
    london
    anyone fancy doing a how to on checking this??? had my clutch/dmf/and slave cylinder changed recently and the guy said they had to add som extra oil when refilling the gearbox as it was low............lets hope they didn't literally fill i t lol
  1. Just filled up How Much?!!!
    By the_wave_rider in forum General Motoring Chat
    Last Post: 19th March 2012, 13:17
  2. should have filled up!
    By TimTay in forum General Chat
    Last Post: 27th July 2011, 14:17
  3. Over filled the oil...
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2011, 11:05
  4. Over filled coolant
    Last Post: 2nd April 2010, 20:42
  5. Just Filled Up
    Last Post: 10th November 2008, 20:34
