Results 1 to 10 of 13
Thread: Dipstick oil levels?
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default Dipstick oil levels?
    I always keep my oil up to the second of the three sections on my dipstick, but today my oil light came on, so I added more oil and this seems to have sorted the problem. I dont want to fill it up to the third section on the dipstick for fear of over filling it, but should I ?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Are you checking with the engine warm?
    Regular Member Jezzy's Avatar
    S.E
    Engine hot, then switch off and wait 5 minutes (for the oil to return to the sump). Pull out the dipstick, clean it, push it back in for just 1 second and the pull out and take the reading.
    So long as the oil is between the MIN and MAX, the level is correct
    If the oil warning light is coming on then there is an issue that needs resolving
    Typically it is the oil pressure switch
    When the oil warning light appeared, did it flash intermittently, or just remain on all the time?
    Which light you talking about. The oil pressure or low oil level light?
    Oct 2007
    south wales
    It was the oil can light on the dash, and it was permanently light. Its the one that goes out when you start the engine. I always check the level when the car has been parked for at least 15 mins to allow the oil to return to the sump.
    There are two oil lights?
    Quote Originally Posted by PeterVV View Post
    That's too long
    As above, the engine needs to be warm to hot and within 5 minutes of switching off
    I tend to wait 90 seconds, then compare again at 5 minutes, just to make sure both readings are identical
    I have also taken readings cold and after 20 minutes, and the reading is higher
    Oct 2007
    south wales
    news to me too?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Yes, on cars with check control there is an "oil level low" indicator as well as the ususal oil pressure light
  1. water levels low
    By pud wayman in forum Troubleshooting
    Last Post: 12th February 2012, 10:25
  2. anyone know trim levels??
    By Morephun in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2010, 15:03
  3. Oil levels.
    Last Post: 29th August 2010, 14:42
  4. vectra-c.com levels
    By aaruck in forum The 'Off Topic' room
    Last Post: 20th June 2008, 01:56
