Thread: vectra dti
    Jan 2010
    norfolk
    Default vectra dti
    hi iv got a airbag light on my vectra 2.0 dti just wondered if anybody had any ideas what it could be thanks
    Barrow In Furness, Cumbria
    It could be any one of a number of things from seat belt tensioners to the air bags themselves. The only to find out is to get the code read. Anything else would just be complete guess work.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    as chris says could be anything from a broken wire,plug ect.you will need tech11 to turn off light if you have fault sorted
    Regular Member Innes's Avatar
    Plymouth
    The most common thing I have seen is the wire that goes into the black box under both the seats coming loose or falling out. It's usually when the car seat is adjusted with a jolt.
    This would be my first check before doing a code reading.
    Jan 2010
    norfolk
    thanks for replies and will look at it when i get time thanks
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
