Thread: engine starts then dies!
    Regular Member distuio's Avatar
    fife
    Default engine starts then dies!
    hi guys, got a problem with my 2.2 petrol sig. had the dreaded car with spanner through it light come on for a few days but it went of after a restart of the engine with no obvious problems. then the car would start and die after about 10 seconds. if the key was removed and wait a minute the engine would start every time but die after the same amount of time. after waiting for several minutes eventualy the engine would stay in and we could get on our way, but the the fault would come back when the engine was turned off, it would start and then die. the fuel pump was replaced a last year at the stealers, but i dont know if the regulator was done. anyone else had similar problems? thanks in advance.
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    sounds like the regulator mate
    fife
    thanks markj123, had my suspisions but wanted to ask as its an itermitant prob. i have a obd2 tool but it isnt reading any dtc codes.
    Aug 2010
    Luton
    mine was intermittent for ages till it went completely
    fife
    ive read the fault is due to the regulator overheating and 'sticking' which allows the fuel pressure to fail to the point where the fuel pressure sensor signals the ECU which then shuts the engine down. that may be why it wont start until a few minutes have passed, ie untill it cools? was your problem solved by replacing the regulator? cheers for the response mate.
    Aug 2010
    Luton
    I had the sensor replaced about 60 quid but must admit thought regulator and sensor were the same thing lol
    fife
    so did i! i'll get on the case next week when things are open. thanks again for your help markj23.
  1. Engine dies for a second or two
    By Swanni in forum Engine & Drivetrain
    Last Post: 3rd January 2013, 19:55
  2. Engine Starts - no Revs
    By webster in forum Engine & Drivetrain
    Last Post: 8th March 2012, 22:18
  3. Engine starts then Dies
    By Mini the Minx in forum Engine & Drivetrain
    Last Post: 21st September 2010, 13:28
  4. How long can a 1.8 SRI engine last before it dies???
    By longer1981 in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2008, 20:08
  5. Fault light comes on engine dies of death
    By mcfly0009 in forum Engine & Drivetrain
    Last Post: 16th April 2007, 17:52
