Thread: Rain sensor gel replacement
    South West
    Default Rain sensor gel replacement
    Following on from my post about rain sensors, the Windscreen has the bracket already in place, but it seems apparent that it still needs the silicone gel pad on the sensor which then makes contact with the screen in order for it to work correctly.
    I have no idea if the one I have bought already has this in place, so would like to find out if I can either buy a replacement, or if there is an alternative solution should I find myself without one?
    Aidi
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    how about a picture of your rainsensor? that would maby help
    No the "gel" cant be replaced.
    South West
    I'll put up a pic when I get it mate
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    :cough: http://www.vectra-c.com/forum/showthread.php?t=135856 :cough: gel bit on the 2nd pic in my for sale add
    Engine : 2.2 Direct
    If Aidi bought the rainsensor from DasArab
    Then it looks like a prefacelift rainsensor (theres no light sensor in that)
    Regular Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    Quote Originally Posted by kenp View Post
    That is not completely true..
    I have had to changed my windscreen twice because og stonechips. And both times the Gel had come as a replacement part with the new windscreen. But Im a not sure you can get it fom VX.. Try the windscreen replacement compagny.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Nope..... you can't just go out and buy a replacement .....not a hope..
    http://www.rejel.com/rejel-store/cat...6/level/a.aspx
    C'mon guys .... a 1 minute Google search !!
    South West
    Quote Originally Posted by Handyandy-UK View Post
    I called this place on Thursday. Nothing specifically for the Vx rain sensor or the Renault salads which uses the same design. They even said that if I bought one and trimmed to the required size, chances are it would not work correctly. Can't see how much difference there can be in silicone myself, but they claim to be the experts.
    This was the only website which I could find doing this sort of stuff.
    As mentioned, I think I'll ask Autoglass. They must have been in he position where they have damaged the gel in he past on various cars and been able to replace. I am sure we would have heard complaints from others if his was not the case.
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    Aidi, even the circuit board is the same, the internal program (code) may be different. This already happen in tranman's parking pilot. He bought one from saab which are in exactly same circuit board as vx's, but no joy to pair to vx cars. So i think a joy would be pop in a scrappy, and find a same sensor case, and swap your circuit board to make it work.
  1. rain sensor help
    By jodiexii in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2012, 15:37
  2. Rain Sensor
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 9th May 2012, 22:59
insignia windscreen replaced but rainsensor does not work
opel vectra c gel pad
rejel rain sensor
