Results 1 to 3 of 3
Thread: Radiator leak
    GERMANY
    Default Radiator leak
    Hi
    I have discovered I have a leak coming from the bottom right hand corner of the radiator (drivers side). Its not coming from the drain tap but just by it. I was wandering if I could put some E metal or metal fill repair on it to stop it or would I have have to get a new radiator????
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi dansoap
    there's no reason you can't repair rad as long as it's done correctly,you don't want to dump coolant out whilst driving up the motorway (or autoban in your case)
    the radiators on the vectras are plenty large enough to stand a slight reduction in air flow if the repair covers a tube or two.
    Regular Member Innes's Avatar
    Plymouth
    I had a leak in the same place. I added Radweld to the coolant and now no leak!
  1. Vectra Radiator Leak
    By salmanking in forum Troubleshooting
    Last Post: 4th May 2012, 19:37
  2. Slight Radiator Leak
    By stevie16v in forum General Chat
    Last Post: 19th February 2012, 15:47
  3. Radiator Leak
    By si_hoss in forum Engine & Drivetrain
    Last Post: 10th June 2010, 13:13
  4. 1.8 sxi radiator leak
    By bat30 in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2009, 12:51
  5. radiator leak
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2008, 07:17
