Thread: Changing calipers
    Jul 2006
    Question Changing calipers
    How difficult is it to change the front calipers? I'm looking at upgrading the brakes to the bigger GSi ones, so presume i'll need to vist the local breakers first....
    You'll need calipers, caliper carriers and the 314mm disc's from a GSi..then use the old flexibles but fit new washers to the banjo bolts on the end of the flexibles as you bolt them into the caliper..
    LMF do a conversion kit..look in the approved trader section for a link to them..
    Jul 2006
    nice one.
    cheers
    Ashington, Northumberland
    clamp off the flexis half way up their length before you start to remove them. That way, when it comes to bleeding them afterwards, it is a very simple 5 minute job as opposed to a lengthy one bleeding the whole system. Once you are finishedthe job and ready to bleed, have your assistant in the car apply pressure to the pedal, once the pressure is applied, then open the bleed nipple. That will immediately force the air out as opposed to letting it creep back up the pipe towards the master cylinder should you open the bleed nipple without pressurising the system. Are you with me? then just one or two pumps of the pedal will do it for each side. HTH
    Jul 2006
    thank god for ppl who know what they're doing!!
    thanks
    Quote Originally Posted by parapaul
    thanks
    Paul, when you come to do it, give me or Mark a PM and we'll walk you thro' it mate.
    May 2006
    Kent
    Try these
    Jul 2006
    Now, them's VERY nice. I saw your post a little while back after you'd just fitted them. If you don't mind me asking, how much and where from?
    May 2006
    Kent
    They are not out yet, in a week or so .. from 888
    Quote Originally Posted by GARY3306
    Top though Gary..
    With brakes, if you're not sure, it can be lethal..so please take us up on gary's offer if you have any doubts..
  1. vxr calipers/ 314mm calipers needed
    By rozzer2006 in forum Handling & Braking
    Last Post: 17th September 2012, 11:28
  2. are 3.2 v6 front calipers the same as 1.9 cdti front calipers
    By gazturbo in forum Handling & Braking
    Last Post: 5th May 2010, 19:11
  3. Calipers!
    By Avenged in forum Suspension, Wheels & Brakes
    Last Post: 28th May 2009, 22:39
  4. front calipers? back calipers?
    By kenny1zero in forum Handling & Braking
    Last Post: 19th July 2008, 08:11
