Thread: Estate tailgate
    Jul 2006
    Question Estate tailgate
    Anyone else have an issue with this? I really have to slam the bu66er to make it shut properly, have had several nights now where the wife has been into the boot for pushchair or other stuff, then when i come to it the next morning, it hasn't shut properly, the courtesy lights have been on for ages etc.
    Is there any way of adjusting the catch or the black rubber stoppers on either side of the tailgate?
    Dec 2005
    St Helens
    Yes this is the only issue we have had with our car. Took it to one dealer they made it worse!, however the second dealer has now made it perfect! So it is adjustable we just let the dealer sort it
    Rich
    Mileage : 000
    I adjusted the latch on the boot floor on mine, it took a couple of goes before I got it right but it is fine now.
    Jul 2006
    Red face
    How does it adjust, ed? TBH, I haven't really looked properly yet!!
    Leamington Spa
    Dads recently failed all together got it fixed under warranty
    Mileage : 000
    Hi paprapaul.
    What I did I got a set of torx ( alen key, the type that are bent 90 degrees) then the torx key will just about fit in the hole without having to remove all of the plastic trim, then I undid the two torx screw,s and moved the plate down a little, then tightened them up again, it is trial and error, if you can put a pencil mark before you start then you will have a guide if you move the plate too much, with the correct type of torx key and a little trial and error you should be able to adjust it correctly, good luck with it any way.
    Jul 2006
    thanks
  1. Estate Electric Tailgate
    By chaddopete in forum Bodywork & Interior
    Last Post: 3rd August 2011, 16:21
  2. Estate tailgate problem.
    By Saxman in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2010, 18:33
  3. Estate Tailgate Adjustment
    By installer in forum Suspension, Wheels & Brakes
    Last Post: 5th January 2008, 17:18
  4. Estate Tailgate not opening
    By Ewormaharg in forum Vectra C / Signum Troubleshooting
    Last Post: 18th October 2006, 19:51
