Thread: Z19DT vacuum.what is this?
    Regular Member tox's Avatar
    Bucharest
    Trim : C
    Engine : Z19DT
    Default Z19DT vacuum.what is this?
    I had this vacuum pipe knackered on the down side, i'm pretty sure it sucked false air there.
    Any idea what it does ? (the red one)
    north east
    COnnects vaccume pump ( Round bit you see through the gap) to the metal vaccume pipes to the boost solenoide and actuator.
    Boost solenoide is the bit at the front of the shot on the slam panel with 2 similar black pipes going into it.
    Just replace with a meter of black 4mm ID silicone hose off ebay about £4
    Bucharest
    Trim : C
    Engine : Z19DT
    this in the pictures is the new one, what happened before if it was broken ? the turbine geometry did not work correctly or what? because after the change, the car is working like never before
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    With that pipe split the boost will be all over the place. I had to buy a new solenoid to fix mine.
  1. Z19DT EGR Blanking Help....Please
    By Vectra Adz in forum Engine & Drivetrain
    Last Post: 28th January 2013, 19:04
  2. Z19DT EML Help...
    Last Post: 19th November 2012, 23:10
  3. Z19DT OP-COM readout
    By Astra H in forum Engine & Drivetrain
    Last Post: 30th April 2011, 13:28
  4. Z19DT EGR Part help please !!
    By johnmac in forum Engine & Drivetrain
    Last Post: 31st December 2010, 19:07
  5. New 1.9CDTI DMF Z19DT - £100
    By danBoy in forum Parts for sale
    Last Post: 7th January 2009, 19:39
z19dt vaccum upgrade
