Results 1 to 3 of 3
Thread: easiest way throug bulkhead?
    Regular Member opel_estate's Avatar
    May 2008
    Sweden
    Vehicle : Opel Vectra C Estate
    Trim : Enjoy
    Engine : Z22YH
    Mileage : 55000
    Default easiest way throug bulkhead?
    I am doing some electrical work and need to run a wire through the bulkhead, what would be the easiest way to do that? (preferably on a LHD vectra)
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Normally on RHD cars you take the glove box out and theres a large rubber grommet that carries the loom from the fusebox. You could always take the plastic under the steering wheel off(bit where the light switch goes) and that should allow you access to the grommet, only held on by 4 or 5 torx screws, you'll need to remove the light switch too.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    The grommit is still there on a LHD vectra.. just a bit more of a pain to get to.. as you have the steering wheel..
    Remove light switch, then remove the 6 screws holding the panel below the steering wheel, then you should be abel to see it.
  1. Water leak from bulkhead??
    By dap1977 in forum Engine & Drivetrain
    Last Post: 9th October 2011, 11:02
  2. Heater Pipes (?) into Bulkhead
    By fifesri in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2011, 21:58
  3. Water dripping from bulkhead after long drive with AirCon
    By muffking in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2009, 14:49
  4. Bulkhead
    By Fingershot1 in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2009, 21:20
  5. Cable through bulkhead
    By paulmac in forum Bodywork & Interior
    Last Post: 20th February 2008, 22:45
vectra c easies way through bulkhead
vectra c sub wire through bulkhead
