can any one tell me how to fit a dump valve as i have been told there is one on it but it a silence kit or something! and it a sabb engine
it is a saab engine and it does have a dump valve of sorts that can be heard if you use a sports airfilter.. I can hear mine just fine... I would not go fitting an aftermarket dump valve though as your engine/turbo recirculates the charged air into the turbo so that it takes less time to spool up. So if you fit a dump valve you will loose that built up pressure and more than likely give yourself some turbo lag. Extra sound but loss of performance, basically a bad idea, should bought a scooby if you want that stuff going on not a family car..
Do the airbox mod listed on this forum and get yourself a sports air filter like a K&N, Maptun or Pipercross, that way you will amplify the turbo dump sound and help the turbo breath thereby possibly increasing the performance a little.
A couple of guys on here have fitted dump valves though, but whats the point in having the sound if you just get burned off by a lad in a corsa who does not have the dump valve sound..
Agree with Nige... You get a decent sound if, like me, you use a cone filter.
Try a cone first as there cheap & if thats not good enough, then get a decent DV..
This is ALL you need:
http://cgi.ebay.co.uk/NEW-EXHAUST-PI...item230e0d62f1
I think Bailey do a split dump valve so part of the charge goes to atmosphere while some is recycled back to the turbo. Might be worth looking out for!
is this one any got
http://cgi.ebay.co.uk/K-N-57i-Induct...item5d29cb9939
or do i get this one
http://cgi.ebay.co.uk/33-2848-VAUXHA...item483cfaade2
any one
http://www.demon-tweeks.co.uk/Produc...ign=Motorsport
Might be that, have a look on Youtube and see if you can find any videos of what it sounds like.
Go for the K&N panel unless you have a heat shield to use.
