Thread: Lowered car but .............
    Full Member spennny's Avatar
    Blantyre
    Default Lowered car but .............
    i now have a knocking , 35mm drop on SRi shocks, should i now change the front and rear shocks, the springs were APEX as thats the quickest ones i could get from eurocar parts
    lincolnshire
    sounds like something isnt quite tight enough on the front shocker tops bud ! have you sorted the rear camber too ?
    Blantyre
    Tightened them all up with an air gun even the front struts while on the car and everything was nipped up, i havent done the camber yet, could this be it ?
    Am off to scotland in the morn, so may try to have it done there
    Edit: Noise is comming from the back hence i think the springs may be just to short and as i hit a speed bump i get the noise ?
    lincolnshire
    you'll rip the rear tyres off in no time if you dont sort the camber aswell as the back end skipping round corners . i've done them with a gun before but still not got them seated properly and although they seem tight , they still knock ! it will be at the front as theres nothing at the back that could knock aslong as your shockers are fit ?
    Blantyre
    Will it be safe to drive ?
    lincolnshire
    yeah should be !? will handle oddly though . you only need two ring spanners and decent eyesight to sort the rear camber
    Blantyre
    Quote Originally Posted by bembo449 View Post
    And where / how do i adjust this
    Or is there someone near edinburgh that can recommend me where to go ?
    Regular Member DaveyVXT's Avatar
    SE London
    I have the exact same problem. i believe its coming from my RARB, i managed to stop it from knocking for approx 2 weeks by lubricating the RARB bushes but they soon dried out again and knock like crazy. I think it could possibly be something to do with the Apex Springs as i also have these fitted to mine. RARB bushes have also been replaced but knocking came back soon enough. i am very tempted to go back to the standard springs to see if that eliminates the problem. its just finding the time to do it.
    lincolnshire
    i've always lowered with eibachs on SRi shocks with no probs , i guess lowering kind find a weekness in the bushes if there is one ??
    Blantyre
    Mine wasnt knocking before the change, so its either the RARB , (is this an easy job) or there is something not tight
    What did you use to lubricate them ?
  1. another lowered C !
    By bembo449 in forum Engine & Drivetrain
    Last Post: 24th June 2011, 22:15
  2. Lowered...
    By P3tchy in forum Styling
    Last Post: 15th March 2010, 12:35
  3. how much will my car be lowered?
    By tim wood in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2008, 21:58
  4. Lowered!!!! :-)
    By LAV6Y in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2008, 14:32
  5. car lowered
    By bish in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2008, 14:48
