Results 1 to 10 of 17
Thread: Shock Absorber desperation!!!!
    Stoke on Trent
    Default Shock Absorber desperation!!!!
    Hi All,
    Currently Lying under my vectra and there is no way for love nor money, can I get the drivers side rear shock absorber back up into the wheel arch! its IMPOSSIBLE!!
    Im beginning to lose my temper with the ****** thing!
    Has anyone done this job and is there a knack to it?
    Help is much appreciated!!
    East Midlands
    ?Front or Rear
    Stoke on Trent
    Apologies..... Rear
    East Midlands
    Old on a minute
    East Midlands
    Right ..so youv'e jacked her up and removed the old i take it.Simply feed the new shocker into the arch locating the bottom fitting,and offer up to the top mount..then lower the jack so she seats into the hole inside boot.
    Stoke on Trent
    thats my problem, I cant get the shock up into the area where it sits, I can't get it past the bolt hole if you know what i mean?
    Stoke on Trent
    Anyone?
    East Midlands
    Quote Originally Posted by smitd004 View Post
    Silly question then,firstly have you bought the correct shock absorber for your motor.
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    if you have the car on a stand(s), use a jack under the rear hub/disk (protect with a sponge or piece of wood).. then jack it up compressing the spring and thereby allowing you to raise the shock up to the top mount..
    if I have the wrong end of the stick let me know...
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Stoke on Trent
    It's not a new shock absorber - its the same one that I took out.
    The hub is no longer attached as I had to change it - had a large crack in it - caused by a very strategically placed rock!
    I've tried jacking it back in, but it just wont budge.
  1. 2.0t shock absorber help
    By stefan7153 in forum Engine & Drivetrain
    Last Post: 8th March 2011, 21:17
  2. another shock absorber question....
    By delberto in forum Suspension, Wheels & Brakes
    Last Post: 20th February 2011, 13:15
  3. Shock Absorber Help
    By Skinner in forum Suspension, Wheels & Brakes
    Last Post: 10th April 2010, 23:23
  4. shock absorber
    By Dwabo in forum Handling & Braking
    Last Post: 30th September 2007, 12:07
