Thread: Outside Temp Reading
    Regular Member Si-SRI's Avatar
    Oct 2009
    LINCOLNSHIRE
    Default Outside Temp Reading
    Wondering if my outside temp sensors up the swanny,today it's been roasting and the most it went upto was 14degrees,
    Went into the Board Computer on the stereo and flicking through the screens
    outside temp 19degrees
    reading 14degrees
    Would you say from that a replacments required or something else.
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    mine went dolally today, just says F now... So will buy a new one, they are cheap and i have had to replace it before..
    Oct 2009
    LINCOLNSHIRE
    Are they easy to replace?
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    yes mate, the outside temp sensor clips in to the lower grille on your front bumper, its about 20cm in from the NS. if you still have your undertray fitted you will need to remove that then reach your arm into the back of the lower grill and tug the temp sensor out of its fitting (just a hole). there is enough slack on the wire for you to pull it back towards you and then unplug the sensor and clip on the new one, then reach behind the grill again and push it into its fitting hole.. Or you could take your bumper off and change it over... Basically its an easy job and takes about two mins once you have jacked up the NSF of the car.... Buy a replacement first, they cost about a fiver on ebay, when it arrives you will see how it fits etc..
    Oct 2009
    LINCOLNSHIRE
    Thanks for that
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    no worries, mine has started working again today but I will have the spare to hand in case it fails again which it is more than likely to do, quite a common point of failure..
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
  1. Unusual Temperature Reading From Engine Temp Gauge
    By mikebeasley in forum Engine & Drivetrain
    Last Post: 1st January 2011, 19:43
  2. temp reading!!!!
    By MORGIE8153 in forum Electrical & ICE (including SatNav)
    Last Post: 19th September 2010, 11:08
  3. Just been reading this
    By Derek Mc in forum General Chat
    Last Post: 10th June 2010, 11:19
  4. external temp sensor reading
    By Deztroyer in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2009, 20:45
  5. Temp gauge not reading
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2008, 17:07
