Results 1 to 10 of 21
Thread: Wheel bearing?
    Woodbridge
    Default Wheel bearing?
    I have a droning noise when I get to about 60MPH, once I get up faster it goes away, if it is below I just get tyre noise.
    I think it is either the start of it, or it has actually gone. Is this a PITA to do?
    And what sort of price?
    The wheel bearings are built into the hub so
    You just change the hub
    I priced some up on eBay the other week at £108 for two hubs Inc postage
    The hardespart is usually removing the hub from the drive shaft spline but if you competent with spanners should take
    No more than 2 hours a side
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    facelift hub bearing about £100-£120 from autovaux, eurocarparts etc etc...
    I'm helping bobsignum with one tomorrow.... about 1hr to 1.5hrs
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Woodbridge
    Quote Originally Posted by marktaylor View Post
    That's a good price. May as well make a weekend of it and upgrade hoses and re paint calipers.
    Woodbridge
    It is on the GSi dean, so its pre face. I think it is the back left, is it worth changing in pairs?
    Woodbridge
    There must be more people that have changed bearings!. It is a common problem on a vec c.
    Regular Member Pete B's Avatar
    Malvern
    I am doing my front nearside on my facelift 1.9CDTi Estate tomorrow, Easter Sun, weather permitting.
    As the car has done 67k, I will be combining it with a pad/disk change so will be repeating some of the work on the other side. A pre inspection shows probably less than a further 10k on the brake pads so doing it early while having the brakes apart anyway will save some hassle later.
    There are "how to's" for the brakes but I couldn't find one for the bearing so I am happy to put one together if anyone is interested although images could be a problem with the uploader being disabled.
    Regular Member Jezzy's Avatar
    S.E
    Ginge - are you referring to the front bearings or rear?
    Woodbridge
    Rear one's mate.
    Woodbridge
    Quote Originally Posted by Pete B View Post
    That would be awesome if you could, Uploading can be done via www.imagshack.com
  1. UJ or wheel bearing?
    By Endricks in forum Engine & Drivetrain
    Last Post: 8th April 2012, 10:49
  2. Wheel Bearing ?
    By jer75 in forum Suspension, Wheels & Brakes
    Last Post: 30th August 2011, 02:01
  3. wheel bearing
    By stuart bigboy in forum Suspension, Wheels & Brakes
    Last Post: 28th October 2007, 17:07
  4. Wheel Bearing with VX?
    Last Post: 6th March 2007, 00:19
