Results 1 to 10 of 14
Thread: Oil in Water on Z20NET Engine
    May 2006
    Mansfield
    Default Oil in Water on Z20NET Engine
    Hi Folks
    Driving back from work tonight, noticed hot oily smell when stationary at lights. Anyway got home, lifted the bonnet - expansion water bottle full of oily mayonaise and under some pressure, oil level right down but no mayonaise in oil.
    What does the team think before I start dismantling - head gasket, oil cooler or turbo ?
    Many Thanks in advance
    SJ
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi sjanisz
    you say cooling system under some pressure but if engine was hot the cooling system is a pressurized system,you need to have a pressure test done or a snif test to check for head gasket failure,but sounds like it may be oil cooler failure,as oil pressure is higher than coolant pressure oil will transfer into cooling system.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by jonnybravo View Post
    Hi sjanisz
    Is the oil cooler not an external one on a NET like the Z22SE (VX220) or is it water cooled a la V6?
    May 2006
    Mansfield
    Oil cooler to my knowledge is bolted on at side of the engine next to oil filter
    SJ
    May 2006
    Mansfield
    Thank you all for your help, can't do anything tomorrow as I'm working but will start the clean up on Saturday and let you know of my progress.
    What is the best thing to get the oil out of the hoses etc ? A colleague recommended biological washing powder.
    Thanks again
    SJ
    May 2006
    Mansfield
    Well finally got back from working away and started the investigation,
    Disconnected the water pipes from the oil cooler, topped up engine oil, started the engine - oil oozing out in copious amounts out of water connections to oil cooler - - off to dealers tommorrow (if they are open ) to get a new cooler.
    Hopefully oil cooler + 'O' rings cheaper than head gasket + associated labour.
    SJ
    [Ex]Admin Duncan's Avatar
    Hope it all goes okay!
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Have you thought of using second hand??..megavox in nottm(sandiacre) are personaly recommended..
    May 2006
    Mansfield
    Thanks Guys,
    Will let you know the end result - what I am not looking forward to is the massive engine degrease and getting all the oil out of the water works (big can of jizer on the shopping list me thinks)
    SJ
    May 2006
    Mansfield
    Well the new oil cooler went on easy enough (wallet's a bit lighter as well!). But can I get the goo out of the water ways - if you pardon the inuendo I've stuck my hosepipe into every conceivable orifice and waited until the water ran clear but it looks like the water pump has a coating of goo as the water is just not circulating resulting in hot spots (and steam !).
    Does anyone know if there is a water pump / engine block drain plug on these things ?
    SJ
  1. Replies: 5
    Last Post: 7th December 2010, 21:48
  2. edt100 water pump (z20net)
    By mat100edt in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2009, 18:24
z20net oil pressure check
z20net water pump drain plug leaking
