Results 1 to 7 of 7
Thread: Elite Air Con
    Regular Member crispy007's Avatar
    Oct 2010
    lincs
    Default Elite Air Con
    I have a problem with my air con
    it wont blow cold air ( with the temp set to low )even after 10 miles or so also when i switch the compressor on it make a scraping noise
    turn of the compressor it stops
    put the normal fan on and its ok
    any help appreciated
    Aug 2006
    Is a very naughty boy
    get it booked into an a/c place for a vac and refill. If they can't get it working they will tell you whats needed, although if your compressor is making funny noises its probably not a good sign. Places like kwik-fit offer a service where if they can't get it colder than it is then they don't charge (well they did last year)
    Regular Member Chris SRi's Avatar
    Jan 2011
    Barrow In Furness, Cumbria
    I've just had mine regassed at Kwik Fit, £49 all in.
    They tested the system to make sure that there were no leaks and showed me the print out showing that the air was blowing out at 22*c before and 9*c after.
    Regular Member Wolflinn's Avatar
    Feb 2010
    Camberley
    Got mine all fixed under main dealer warranty, but for some reason kwik fit get it colder when regassed than my main dealer can.
    Oct 2010
    lincs
    Quote Originally Posted by Wolflinn View Post
    hi thanks for your reply
    my car is still under manufactures and network q warranty so will it be fixed foc
    Feb 2010
    Camberley
    Yes they will repair as long as damage has not been caused by a stone chip.
    So if you just have a leak or compressor is faulty they will fix foc
    Oct 2010
    lincs
    thanks for the info got it booked in week after next
  1. Off to look at a Signum Elite. Elite + suspension = GSI?
    By Yugguy in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2012, 10:42
  2. LS to elite
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2012, 13:03
  3. 2.8 elite springs on a 3.2 elite!
    By Ziggy in forum Handling & Braking
    Last Post: 12th April 2011, 18:51
  4. Bsr ppc 2.8t elite
    By LOCKSTOCK in forum Engine & Drivetrain
    Last Post: 12th September 2009, 22:00
