Thread: Poor start from cold ?
    Doncaster
    Default Poor start from cold ?
    Hey guys..
    Over the last few weeks my 1.9 CDTi vectra has developed a bit of a struggle firing up from cold.
    It Fires up with no problem at all the second time even if i've only driven a 1/4 mile, maybe even less.
    Then the other day it seemed a little worse and after it fired it sounded a little choked and un-responsive when I gave it a little throttle then a ploom of blue smoke drifted past the car. After that I drove home smoothe as you like.
    Any ideas what the problem could be ? I'm kinda preying it'll just be a glow plug problem or maybe a battery problem ?
    Thanks in advance.....
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi VP
    sounds like glow plugs,you say maybe battery,is it slow turning over or churning for quite a while,if cranking speed is as usuall then i would go for glow plugs testing.
    lincolnshire
    try heating the glow plugs more than once on initial cold start up ! if its starts easier then your glow plugs are goosed
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by jonnybravo View Post
    Hi VP
    Doncaster
    Yeah it turns over easy enough but takes a few more turns than usual on the first start from cold so I'll buy myself some new plugs then. I will try the heating them up twice first though just to make sure.
    Is there any real benefit in gowing for the more expensive plugs over cheaper ones ?
    Jul 2009
    Engine : 20 Dti
    You can't go wrong with Bosch bud
    Regular Member steve19cdti's Avatar
    Nov 2010
    s.wales.bridgend
    i had that problem changed glow plugs did nothing mate change battery fires first time now
  1. Poor starting.................but not from cold
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2013, 07:32
  2. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  3. cold start smoke and poor running engine
    By Tredici in forum Engine & Drivetrain
    Last Post: 16th January 2012, 08:40
  4. Poor starting 1.9 CDTI 120 Hot & Cold
    By lehapau in forum Engine & Drivetrain
    Last Post: 4th October 2011, 20:06
  5. 03 vectra dti poor starting when cold
    By jono m in forum Engine & Drivetrain
    Last Post: 11th November 2010, 14:16
