Results 1 to 10 of 16
Thread: Z19DTH Pre-Cat Removal
    Aug 2010
    Stoke on Trent
    Default Z19DTH Pre-Cat Removal
    Can this job be done entirely from under the car as access from the top looks to be a nightmare...?
    Aug 2010
    Stoke on Trent
    bump
    Dec 2010
    Torquay
    I was looking at doing this to my car too.. will follow this thread..
    Regular Member AndyFoz83's Avatar
    Jan 2010
    Wolves
    same here
    Aug 2010
    Stoke on Trent
    Hmmmm... the silence speaks volumes... I'm guessing I'm on my own with this one... I'll try and make a how-to while I'm at it.
    Regular Member johnnyboy1985's Avatar
    Aug 2010
    Letchworth Hertfordshire
    When i had mine fitted at MIJ they went from the bottom and top....i was under the impression that it was easy enough to do at home but the guy who did it was a bit of a ****
    lincolnshire
    Quote Originally Posted by johnnyboy1985 View Post
    ha ha , seein your sig pic makes miss my first black C ! was a lovely motor that one
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Had my local garage fit my de-cat pipe. I did get underneath and have a look at it, but didn't rate my chances of holding everything together and balancing the locking ring over the 2 ends.
    Oct 2010
    Darlington
    Yes it is not as difficult a job as it looks. Start by getting the undertray off. It obviously helps if you have access to a ramp
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    I done it te cheap way. Jacked up front of car took off undertray
    Removed 2 17mm bolts holding exhaust to gearbox ten removes 3 13mm nuts securin the down pipe tonthe pre cat. I then dropped the exhaust out the way as it's on the flexi it rested in the floor. I then removed the 17mm collar holding the temp sensor in the pre cat pulled that out the way and then drilled through the pre cat material with a big drill bit to hollow it all out so it's not a hole all the way through and runs like a dream and looks as standard too hope this helps cost me nothing lol
  1. Z19dth DMF
    By neill in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2012, 15:30
  2. Oil for z19dth
    By neill in forum Engine & Drivetrain
    Last Post: 18th July 2011, 18:45
  3. z19dth
    Last Post: 22nd April 2011, 08:38
  4. Z19DTH - Which Oil?
    By treadstone in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 17:22
  5. z19dth
    By taralko in forum Vectra C / Signum Troubleshooting
    Last Post: 1st July 2006, 13:36
z19dth precat
vectra c z19dth catalytic removal
vectra c cat removal www.vectra-c.com
z19dth pre cat mr muscle
