Results 1 to 10 of 27
Thread: AirBag light
    Regular Member Steven T Davies-Moss's Avatar
    shropshire
    Default AirBag light
    my airbag light came on after my wife clocked up many miles in one week
    iv purched a replacement Airbag ECU and had the data transfered over but the light is still on
    are my options limited now. ?.. and can i identify the exact cause of the fault ?
    Tim
    Full Member Big Sig's Avatar
    Tech 2 would tell you exactly where the fault is, although its also as likely that its a seat plug where she has moved it about or stuck some shoes under the seat.
    shropshire
    Aha.. loadsa stuff gets wedged under them seats.. and we move them every time we swap drivers
    ill check the plugs... i take it they r easy to get too .. underneath
    Yeah not too bad, lift the seat up on its height adjuster to make it easier. There will be a couple of multi plugs under there, one will be for the seat airbag.
    shropshire
    i found one big fat main black plug.. and one small orange one for prob the seat belt pre-tensioners
    Unplugged these and re-plugged and still i have a light
    guess im just unlucky
    Always worth checking for free. have you checked both front seats?
    shropshire
    yep. iv not missed a plug have i ? ... gonna re check to be sure cos one seat was rammed with stuff ** kids toys **
    Otherwise im goin to remove power for a couple of hours.. think its the negative terminal ... Soon find out
    shropshire
    still no luck
    DAMN U VECTRA
    gonna have to drive round roundabouts now till some old fart ***** me
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    does this airbag light only relay faults from the dash and steering wheel airbags?
    Quote Originally Posted by Caveman_nige View Post
    No, the whole system as far as I know.
  1. Airbag light!
    By joee91 in forum Electrical & ICE (including SatNav)
    Last Post: 25th June 2012, 01:52
  2. Airbag light
    By Sharpy28 in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2012, 22:26
  3. AIRBAG light .. is thier a fuse the the Airbag ecu ?
    Last Post: 10th September 2011, 13:21
  4. Airbag Light
    By rocket999 in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2011, 16:22
  5. Airbag Light
    By Hollingsworth87 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th April 2011, 16:29
