Thread: Creaking clutch pedal
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Default Creaking clutch pedal
    When I press the clutch pedal it creaks and its not as smooth as it used to be.
    Would lubricating it fix it??
    If so what should I use and where should I apply it?
    Regular Member mann3210's Avatar
    scotland, perth
    silicon grease, its got a nylon bush at the top of the pedal that squeeks, just cover your pedals with a cloth so you dont spill anything on them! pump the pedal a couple of times job done!
    Jun 2006
    North West
    Quote Originally Posted by mann3210 View Post
    Will this stuff do the job? http://www.halfords.com/webapp/wcs/s...egoryId_165705
    If so I'll get some at lunch and give it a go.
    Jun 2006
    North West
    Well I had a look at lunch time.
    I can see the spring on the clutch pedal but not a bush.
    I can feel that the pedal goes a bit further up behind the dash.
    There is a plastic cover that goes across the top of all the pedals so I removed three torx screws from the front of this cover where it meets the dashboard panel (the one that your knees would hit if you move yourself to far forward). But the cover does not want to move.
    How do I get to/see the bush?
    Jun 2006
    North West
    OK I had another go at removing the panel. Its all one piece not two as I first thought.
    So there are 3 TX20 screws underneath. 2 more between the panel and the steering column. And a sixth that's hidden behind the light switch.
    With the panel off its a little easier to see things. I still couldn't see a bush.
    So I sprayed the spring and its mounts and, as best as I could, the top of the pedal where it pivots.
    The noise is even worse now!!
    So I'll have to live with it....
    Jun 2006
    North West
    Well I'll take it all back. The creaking has gone.
    Must have needed overnight for the grease to penetrate
    Thanks for the help Mann3210
    scotland, perth
    hi mate, if you got a can with a nozzle straw that woulds of been alot easier, just point it up @ the top of the pedal where it pivots add just spray, youl now know for next time haha
    Berkshire
    Quote Originally Posted by Marky View Post
    Hi - how on earth do you remove the the sixth screw behind the light switch? I cannot see how to get to it - the panel needs to come off by the looks of it. But i cant get it off because the 6th screw is holding it on!
    thanks
    Nick
    Jun 2006
    North West
    Quote Originally Posted by Nick1_S View Post
    The screw was obvoius once the panel as removed.
    So I am guessing you are having trouble removeing the light switch panel?
    If so you need to:
    Push the headlight on / off switch in, turn it to sidelights (middle setting) then pull then it should come out.
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Creaking clutch pedal
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2012, 12:12
  3. Creaking clutch pedal
    Last Post: 10th June 2009, 20:23
  4. Clutch pedal
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2008, 23:53
  5. creaking clutch pedal
    By north in forum Engine & Drivetrain
    Last Post: 13th October 2007, 14:42
squeaky clutch on insignia
vectra c clutch creaking
insignia clutch creak
