Thread: Noise from Auto box
    May 2007
    West Yorkshire
    Unhappy Noise from Auto box
    As the title says really, had the Vectra in for the aircon compressor swapping under warranty and I have since noticed @ low speed if I let my foot off the throttle every now and again I hear a metallic rumbling/spinning noise? It happens more about 5-10mph and seems to be if I press the throttle and lift off quickly just before gear change. If it was manual I would swear it was clutch related. I also have another noise I need to get them to look at, it sounds like a bearing around the cam/alternator side of the engine, worse from cold but still noticeable when warm
    Grateful for any idea's before I book it back in which will need to be soon as it's done 53k.
    Thanks in advance
    May 2007
    West Yorkshire
    No-one?
    May 2007
    West Yorkshire
    bump, surely someone knows about auto boxes
    Regular Member Mopar Man's Avatar
    herts
    Seems odd that since you had the compressor replaced?
    Does either of these noises disappear, when turning the air con off or on?
    Difficult unless i hear it myself, sounds diff related on the box. A big IFF.
    May 2007
    West Yorkshire
    Thanks for the reply, it may well have been there previously as it's only noticeable when you throttle and then release sharply, sounds metalic. A bit like a dry bearing and something spinning (metal on metal) Tried with the AC off and no difference, tried when car is stood still and can't get it to do it. Diff related would make sense, it needs to go back for the other noise anyway so I will get them to listen to this.
    I just wanted them done before the warranty expires in 6k miles.
    Thanks again.
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  3. Help needed - Auto dim mirror & poss auto wipers
    By mark_647 in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2009, 01:09
  4. Auto wipers.. and auto dimming mirror ?
    Last Post: 28th January 2009, 01:24
  5. Strange noise on kickdown - turbo or Auto?
    By NPS in forum Engine & Drivetrain
    Last Post: 14th August 2008, 12:51
