Results 1 to 2 of 2
Thread: mil light on three fault codes
    Apr 2011
    runcorn
    Default mil light on three fault codes
    my 05 plate vectra 2.0 diesel has the mil light on intermittantly with fault codes P1105,P0105,P0110 is this a knowen fault.
    West
    The first 2 codes relate to the map (boost) sensor, the other relates to the maf (air flow) meter...
    Start by cleaning the boost sensor which is located on the inlet elbow... do the elbow while your at it, it all usually gets gunked up... clear the codes & see what comes back, some people advise cleaning the maf too, if you do this do it with care as you could make it worse.
  1. Fault codes P1109 and P1110, emission light on
    By kristapsl in forum Engine & Drivetrain
    Last Post: 21st January 2013, 01:07
  2. Fault Codes: Shed Some Light Please?
    By paz_badboy4life in forum Electrical & ICE (including SatNav)
    Last Post: 25th March 2012, 21:39
  3. Replies: 13
    Last Post: 20th May 2010, 20:09
  4. Emissions Light- Fault Codes
    By Stu_2010 in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2010, 21:06
  5. Spanner light/limp home/fault codes?
    By Factory Pilot in forum Engine & Drivetrain
    Last Post: 17th June 2009, 09:09
vauxhall signum codes p1105;p0105 site:www.vectra-c.com
