Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
Thread: Rain/Light Sensor Fit
    Full Member
    South West
    Default Rain/Light Sensor Fit
    Right chaps,
    New windscreen into today.. complete with the bracket for the lights/rain sensor.
    Sourced a roof loom cable with lighted visors, rain sensor, mirror etc.
    I have read a few old posts about getting the sensor to stick to the windscreen. These were 2008 posts, so is there now an easier way to do this, or can i even get the gel sticky thing by itself?
    I am assuming the sensor i have found is likely to only be the rain type, is there a part number for the one which does both Rain and Auto Lights?
    I know i will also need a new headlight switch module with Auto, so might as well go the whole hog and get it all done then Tech2'd in one go.
    It was kenp who started the retro fit post a while back so any input you might be able to inject would be useful.
    Aidi
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Quote Originally Posted by Aidi View Post
    Right chaps,
    Aidi
    If you have the correct windscreen then the sensor clips into the bonded bracket.
    I retrofitted this to my facelift.
    Full Member
    South West
    Good point!!
    Does this bracket (which i have) negate the need for this silicone gel ? Wasnt too sure if the gel was only for securing it, or if it played some part of the operation of the sensor?
    @home
    Engine : 1.9 CDTi
    Good point!!
    I just clipped mine on, no gel.. it's not moved since I put it there.
    Full Member
    South West
    Thanks mate. Thats one area sorted.
    Dont suppose you know how to identify if the sensor is just for rain or rain/auto lights?
    @home
    Engine : 1.9 CDTi
    There should be a single cell that seems separate from the rest. Alos there's two types of connectors for the sensor... I needed the smaller connector:
    Small
    Large
    Full Member
    South West
    That should not be a worry for me, i have found a set which comes complete removed from a 07 Vectra.
    Its just that i dont know if its just a rain sensor or a rain and auto lights sensor.
    Full Member
    South West
    oops. duplicate post
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    That silcon gel layer is part of the rain sensor.. It can peel off but should be attached/part of it. Its something to do with the gel sensing the rain.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    if you have a rainsensor from a facelift, they are all ready for lightsensor too.. (remember you then if want autolights) also to get a lightswitch for autoligts..
    ive retrofitted rainsensor too.. (cant have autoligts thou )
  1. Rain/light sensor mount.
    Last Post: 15th January 2013, 20:31
  2. right wire for light/rain sensor
    By khile in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2012, 21:54
  3. For Sale: Half Can Rain/Light sensor (2 available)
    By lee gsi in forum Parts for sale
    Last Post: 8th August 2011, 20:06
  4. Rain & light sensor
    By Dave78 in forum Electrical & ICE (including SatNav)
    Last Post: 21st March 2011, 17:19
vectra c light sensor
light sensor vectra
fitting rain light sensor vectra
vectra c windscreen with light sensor
https:www.vectra-c.comforumshowthread.php135796-Rain-Light-Sensor-Fit
vectra c rain sensor
vectra c rain sensor bracket
corsa c rain sensor light sensor
