Results 1 to 10 of 11
Thread: Code p1125
    Regular Member collyb's Avatar
    Mar 2011
    ireland
    Default Code p1125
    well guys,,was getting sick and tired of my limp mode/spanner light saga,,,,,, after all the work that had been done,,,(new inlet mani,glow plugs,egr and boost sens clean,full service..\),,so i went out today and bought a fault diagnostic scanner meself,,,, and i got code p1125,,,which i think is throttle body related ??? so i tackled the throttle body today,,,,gave it an UNREAL cleaning,,(it was seriously coked up ),,,and i re soldered only one of the solder joints on the small black module underneath the TB( thanks to the how 2 on this site) i only re soldered one of the solder joints on the circut board as it was the most suspect looking of all the joints,,,,, put all back together and do a re scan with my scanner and came up as zero fault codes,,,,and all looked good,,,took her down the road for a drive,,,,next thing,,spanner light/limp mode again!!!!! switched the car on and off,,,and all was good again,,,,, now it seems to be driving fine and still no faults registering on my fault reader,,,,,,,,,,,,,,any ideas ???????????
    scottish region
    Throttle position sensor i think mate
    Mar 2011
    ireland
    do u mean i need a new one,??? where is the tps located ????????
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by collyb View Post
    There is a how2 as your car is '05 it will suffer from broken solder joints in the throttle body housing.. Nothing solder and a soldering iron won't cure.
    I just removed the throttle tbh.
    Gazza4
    Mar 2011
    ireland
    i re soldered only one of the joints gaz,,,should i have done them all ??????????
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    One of the chips on the board apparently look bad and need doing but it is recommended you do as much as you can.
    Gazza4
    Mar 2011
    ireland
    well i did the one that looked the worst ,,but i guess i should have done them all....this car is a mystery to me,,,......
    Regular Member daveypower's Avatar
    Mar 2011
    Donegal
    dont give up man, keep going youl get her sorted yet. youl be a vectra mechanic by the end of it lol
    Mar 2011
    ireland
    your telling me davey..lol i see your a donegal man,,only up the road from meself
    Mar 2011
    Donegal
    yea good old hills of donegal, where ya from man?, get her sorted yet? or should i have a look through donedeal lol
  1. Fault code p1125 app system help please !!
    By WDUK2005 in forum Engine & Drivetrain
    Last Post: 8th August 2011, 16:36
  2. code p1125 (61)
    By the-wizard in forum Engine & Drivetrain
    Last Post: 8th July 2011, 18:33
  3. question on code p1125
    By collyb in forum Engine & Drivetrain
    Last Post: 24th April 2011, 15:34
  4. fault code P1125 ??
    By cov in forum Electrical & ICE (including SatNav)
    Last Post: 24th September 2010, 12:10
  5. Oh Dear, How bad is a P1125 Fault Code
    By markm in forum Engine & Drivetrain
    Last Post: 11th September 2010, 23:07
