Thread: 2.2 direct sri, sluggish untill engines warm?
    Apr 2011
    milton keynes
    Default 2.2 direct sri, sluggish untill engines warm?
    Hi im new to this can anybody help me, i have two faults with my 2004 vectra 2.2 direct sri.
    1. From cold its very sluggish when i accelerate slow or fast untill the engine has warmed up then runs perfectly?
    2. I travel 3 miles to work and if i try to start the car between 1-3 hours after this jurney the car Will only start 2nd or 3rd attempt, if i leave it longer/overnight it starts fine, or within the first hour after jurney will start fine.
    Any ideas on what could resolve these problems? please Help ive changed the coil pack and plugs. now im stuck on what to do next. Thanks
    Regular Member Sambor's Avatar
    Elgin
    Did you change high fuel pressure regulator for free?If not call your VX dealer!
    Apr 2011
    milton keynes
    That was changed by the owner before me, any other suggestions?
    Regular Member HITFACTORY1403's Avatar
    Mar 2011
    NEWCASTLE UPON TYNE ( Shiremoor )
    my 2.2 direct petrol Design has a slight , what i can only describe as an " air noise " , going , " put put " or " fit fit " on start up , not loud , but once warmed up a bit , it goes away ...
    does any one elses engine / exhaust on their 2.2 direct petrol make a droning noise like a world war 2 bomber or boy racer exhaust , when excellerating from 2nd to 3rd gear ? ............... i have had suggestion from it being the normal induction sound of the exhaust to it could be the baffles , but i ain't a mechanic to know what it all means ..
    thanks for any help ..
    if i have hi - jacked dj421 's post , i will remove mine , but as we have the same 2.2. direct , i thought any info given we could share ...
    have a nice day .
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Quote Originally Posted by HITFACTORY1403 View Post
    i fried of mine had a symptom like this on a pajero diesel and it turned out to be the exhaust gasket leaking when cold on one cylinder.
    al.
    Mar 2011
    Quote Originally Posted by Al 22 dti View Post
    al.
    thanks Al , i will try and borrow my father in law's ramps to check ....
    do i use the old washing up liquid trick to find the leak ?
  1. I was interested in the engine untill i read the description
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2012, 23:41
  2. 2.2 direct engine starts cold but doesn't warm?
    By barnesy in forum Engine & Drivetrain
    Last Post: 19th December 2010, 12:09
  3. 2.2 Direct warm engine start
    By Sambor in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 22:12
  4. Dodgy fuel pumps on 2.2 direct engines?
    By mafb in forum Vectra C / Signum Car Chat
    Last Post: 22nd September 2008, 22:45
  5. are 2.2 direct engines any good?
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2007, 14:37
vectra 2.2 sri sluggish
vectra 2.2 direct slow when cold
