Thread: LED Fog Light Help..
    Liverpool
    Default LED Fog Light Help..
    Ok so I bought some LED sidelights and LED foglights from the same company on Ebay, I've read about this CANBUS error people get so I made sure I got some error free ones
    The LED sidelights work fine, they do the usual 30 second flashy thing when I turn em off but apart from that they are fine
    Ive just changed the foglights for my LED ones (same brand as the sidelights) but they just refuse to work, my onboard computer just says there is a problem with them, and I get nothing...
    Is there something blatantly obvious that I have missed? or do they just not work
    My other theory i was going to try was to wire the original foglights to the LED ones...was going to make a female to male spade splitter cable, put the LED ones where they should be, and then just tuck the original foglights out of the way..
    Im no electrician but I think that would work?
    Any help is greatly appreciated!!
    Regular Member eaglepva's Avatar
    Up North
    Im not sure but think somebody on here said that you need to change the wires round. So the one that is loose needs to be but where the solid one goes or something like that.
    Liverpool
    The foglights only have one connection on them anyway, I think it just uses the casing of the fog light holder as the earth
    I think what im probably going to do is wire them from the sidelights or something...or maybe I just bought dud foglights!
    North West
    i asked this question and was told to swop the pos and neg around as leds are dirrerent to normal bulbs.or you can put hand inside fog unit and swop the connections in there,the leds should work then.i still not got round to do mine yet
    Regular Member the-converter's Avatar
    Australia
    You can try to put a 50w resistor (shown in the picture) across the positive and negative wire of the foglights. This will bypass the CANBUS error but what I'm not sure is whether the LED will do the usual 30 seconds flashy when you turn the foglights off.
    Quote Originally Posted by Coggy69 View Post
    Liverpool
    Yeah using a resistor isnt a bad idea, but dont the foglights just have a positive power cable on them and use the casing of the fog light unit as an earth...?
    Australia
    My foglight has a positive & negative wires.
    I'm 100% sure because in the past I have tapped the LED strip wires to the foglight's + & - wires.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
vectra c led fog lights
Vectra c fog light bulb led
vauxhall vectra led fog lights
vectra c xp2 fog light adapter
vectra c led fog
vectra c what fog lights bulbs
led fog light bulbs for 2006 vectra
2008 vectra changing foglight bulbs
