Thread: Engine and wheel problems...
    Apr 2011
    Portsmouth
    Default Engine and wheel problems...
    Firstly, hi to everyone reading this and apologies if this is in the wrong area.
    I happened across this site as it seems its all google knows! LOL
    So, guess I'll just spread my woes here and see if any of you vauxhall owners have any ideas or advice!
    The car is a 2005 Vauxhall Signum 2.0T petrol Design 95k miles.
    I have a few problems, so I'll list them all here instead of separate threads..
    (All my ideas have come from other answers I have found via google and here LOL)
    Problem 1 -
    When driving, there is a heavy vibration coming from the drivers side front wheel. I can really feel it in the steering wheel and drivers side floor.
    You cant feel it anywhere else, only drivers side. I had the front shocks, and all the tyres replaced only a few hundred miles a go.
    I have swapped the wheels around so I can only guess its not the balancing etc.
    Could this be a hub or drive shaft problem?
    Problem 2 -
    When driving around tight bends or roundabouts, sometimes the rear end feels really wobbly, or loose, like its going to lose grip etc. It does it randomly and in all weather.
    Rear control arms?
    Problem 3 -
    When starting up the engine from cold it makes a little knocking noise, Its done a lot of miles, so I guessing this is just the valve tappets?
    Problem 4 -
    When starting the car from warm, the idle is quite rough for a few minutes, the revs dip and rise by a few hundred revs. I did notice the car had a little too much oil in since the last service, I had to drain about 1/2 litre to bring it below the max cold line. Could that have damaged anything?
    Thanks for taking the time to read!
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    What tyres are you using?
    Regular Member Jezzy's Avatar
    S.E
    Problem 1 - is there any noise that accompanies the vibration?
    Problem 2 - that does indeed suggest that the bushes in the upper rear control arms are worn.
    Apr 2011
    Portsmouth
    Hi there thanks for quite replies,
    The tyres are I think zumho Extra load (Something like that? - Budget brand TBH) on VX genuine 18 inch wheels.
    I cant hear any noise when driving, what kind of noise should I listen for?
    Apr 2011
    Portsmouth
    I cant hear anything when driving, but it does feel like it knocks a little, like a bolts loose or something on the lower of the strut?
    Regular Member daveypower's Avatar
    Mar 2011
    Donegal
    Quote Originally Posted by HKW View Post
    check your track rod end, it will cause vibration at higher speeds and also knocks on bumps, and changing from 1st to 2nd.
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    i can pop round this weekend and take a look at for you if you like, let me know if i need to bring a trolley jack.. we will soon figure out what the problems are... there isn't much on these cars that i haven't taken apart or modded for some reason..
    Jun 2009
    South Coast
    my diary is filling up quickly mate... send me a pm if you want some free help, I have all the tools and i won't bite..
  1. Help please engine problems
    By 11mallard in forum Engine & Drivetrain
    Last Post: 6th April 2012, 18:54
  2. more engine problems
    By johnnyhg in forum Engine & Drivetrain
    Last Post: 11th February 2011, 23:18
  3. 2.0T Engine problems...?
    By n_hudson in forum Engine & Drivetrain
    Last Post: 4th February 2009, 17:43
  4. Engine Problems
    By Madmarky01 in forum Engine & Drivetrain
    Last Post: 1st April 2008, 12:44
  5. 1.8 SRI engine problems....
    By bigd1975 in forum Engine & Drivetrain
    Last Post: 12th May 2007, 19:59
