Thread: low power above 1800rpm eventually resulting in LHM
    Mar 2007
    Sheffield
    Default low power above 1800rpm eventually resulting in LHM
    Low power after the normal boost point around 1800rpm. It's like when my EGR went however this time there is no plooms of black smoke intact the fumes from the exhaust are very clean!
    When LHM kicks in which was about after 5 miles I was limited to 3500rpm max.
    About 40k ago I had EGR, diesel particulate filter and more.
    Plenty of pressure in the turbo hoses!
    Any ideas of where to start?
    Mar 2007
    Sheffield
    some use you lot are!
    I ended up getting a OP-COM and was VERY pleased with the functionality and features despite the one I recieved having a intermittant fault where it works when it wants to. Seller informed for a swap out hopefully.
    So now I have a few errors to work though...
    P0530 - A/C Pressure Sensor Circuit High Input
    (07) - Not present
    P1482 - Fan Control 2 Circuit Open
    (04) - Present
    P0234 - Boost Pressure Control Circuit Positive Deviation
    (5B) - Not present
    The last of these seems to be the issue im having based on other users info from this site.
    So whats the correct route to follow to fix the problem???
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Have you tried clearing faults and going for a drive again to confirm?
    Have you checked all the pipes?
    Mar 2007
    Sheffield
    After stating to strip the turbo following reading a thread with very similar symptoms my assistant spotted a split cable while i was "head under car"
    Sure enough it was the vacuum hose operating the turbo, under high revs it was giving a little vacuum but very little, the hose was right at the point of not functioning at all and only working about 10% of normal function.
    £2 of fuel hose (a little thicker than I would like but VX couldn't find let along supply the hose I asked for due to no part number printed) and a jubilee clip on one end due to the size differences and its boosting like a "good'un"
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Which of two engines on your profile are we talking about? No need to exclaim how useless we are, just bump the thread as most others do because at time of writing the people who can help may not be available. Also state the engine which is giving you trouble - CDTI 150 I presume?
    Admin plasma's Avatar
    On the Forum
    259 Post(s)
    Engine : 150
    Mileage : 74000
    was probably a dti with that problem gazza
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
  1. CDTi-150 Flat Spot @ 1800rpm
    By Signum7060 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th July 2012, 07:27
  2. Woop Look what eventually came today :)
    By DarylAAS in forum Insignia car chat
    Last Post: 26th February 2011, 06:38
  3. eventually got some pics of my V6...
    By swirl80 in forum Quick Photo Album
    Last Post: 24th August 2009, 20:33
  4. Eventually fitted my Caterman
    By RobW in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2009, 15:03
  5. Eventually changing to 225/45/17s??
    By marky2027 in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2008, 19:43
