Thread: GRRRRRrrrrr
    Apr 2011
    midlands
    confused GRRRRRrrrrr
    Hi again i was asking yesterday about the injector 3 on my 54 1.9vectra and was told that the copper seal can just be fished out but i cant do it. i have seen on other posts that its not that simple.. However the other thing is if its just an injector thats not working would my car still start... since i have messed with the injector the car is just turning over but nor starting up!! Do i need to bleed the pipes?? or have i done somthing wrong??
    Please help
    Sodding Typical on Sea
    To retrieve the washer use a bit of blutak on a rod it should adhere to it, and it does sound like the system has an airlock as nothing you have described should prevent the car running even if it was on three so I would be thinking along these lines first.
    Apr 2011
    midlands
    whats the best way to remove airlock??? if i can just get the thing running then i can see if the seal need replacing or not!
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    You would know if the seal had gone as you would have sludgy oil coked carbon all around the injector, this happened with my 1.4tdci fiesta.
    I had no problems starting after I changed all 4 seals.
    Possibly an electrical fault? Do your injectors need re-coding once removed?
  1. Vec c indicators grrrrrrrrrr
    By Edit100T in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2013, 23:26
  2. Brakes Grrrrrrrrrr
    By Tam80 in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2011, 22:51
