Thread: Seat removal ?
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Default Seat removal ?
    Are the seats in the insignia similar to removing the ones from a Vectra c ?
    Plus unlike the Vectra it seems airbags are not visible is there anything I need to do before taking seats out ?
    Irmscher Insignia CDTI 130
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Regular Member Jezzy's Avatar
    S.E
    At a guess, you need to disconnect the battery, wait at least 15 minutes, then disconnect the electrical connectors under the seats.
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    Hi mate, they are just like the vectra, dont forget there will be a wire connected to the seat belt buckle as well as the pre-tensioners
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Anyone know how the tabs on seat tensioners unplug ? Got seats but looks like they ripped the seat tensioners plugs off so need to get mine off and solder on to new seats.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Was thinking of changing looms but tried tonight to remove old loom without success I'm ok till I get to loom that goes into back of seat, then there's no room to find where they go. I presume it's to airbag and lumbar mech.
    Now the only plug missing is a small locking tab conector (on phone so can't post pic)
    It has 2 wires going to it, now the electrical minded of you could I just snip my old plug off and solder and tape new one on without any problems ?
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    for above
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quote Originally Posted by bigmac View Post
    don't want to butcher the plug off my old seats but don't think I have another option
    If I did remove plug would it be ok to solder and tape it up to new seats ?
    S.Wales, Nr Swansea
    Im sure when I did mine mate, you pull the tab out before you remove the plug, its a type of locking pin system
    Oct 2007
    Shropshire
    Solder and heat shrink will likely cause no problems, but I would check what the wire did.... If it was an airbag or tensioner system then I would not do it and I would get a new loom or find out how to strip your seats to get the old wiring....
  1. seat removal
    By dilan in forum Bodywork & Interior
    Last Post: 29th April 2012, 15:37
  2. Seat Air bag removal
    By Das in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2010, 00:01
  3. seat removal
    By texaspete1973 in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2010, 20:51
  4. seat cover removal help
    By barrymanalow87 in forum Bodywork & Interior
    Last Post: 9th September 2009, 22:34
  5. rear seat removal
    By bigearmuffs in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2008, 21:08
